Thread: Gotta change rear bearings and shoes 95 110
    Pacific NW
    4,255
    Sorry, 85 - 110 cant get to change the title.
    Any thoughts?
    pop seals, tap out bearings?
    Any hidden clips or snap rings?
    Neighbor passed away and I need to get this sold for her son.
    28 degrees out but sunny.
    Just could do nicely without surprizes.
    whole axle carrier has to come out of the frame to replace bearings?
    thanks
    Cold Lake, Alberta, Canada
    3,019
    Can't say I've done a 110 but 90's should be the same. I've always removed the carrier so I can put some effort into it. They can be tricky if seized in. First, pop out your seals. There should be a floating spacer that should move back and forth when you look inside. Once it's all the way to one side it will expose a tiny portion of the inner bearing ring. There may even be a cast cutout to allow for access? Trying to remember here; having some beers:-) Suspend your carrier on two blocks of wood a on a brass punch downward. The blocks of wood will really come in handy when pounding down on the brake side of the carrier to compensate for the fixed brake shoe mount. You may have to alternate side to side. Let us know how you make out.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Jul 2013
    mo
    327
    Here you go. Hope this helps.
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Pacific NW
    4,255
    it got dark and freeeeeZing into the teens so we quit for the day.
    Drum's off, new shoes will fit so we made it that far.
    My last drum took 3 weeeks to get loose.
    When the rear carrier comes off, at least I can bring it in by the woodstove.
    sheeze, even the tools were freezing my hands through the gloves.
