Results 1 to 3 of 3
Thread: 87 Tecate..Rust or corrosion in water cooling holes in head
    Warsaw, IL
    862
    Welp, I pulled her apart tonight to measure the BORE. Hoe much is a head, and base gasket? There was soem Rust/Corrosion in the Water coolign holes in the head, what does this mean? How do I fix it? is it normal?
    1969 Trail 70
    1973 ATC 70
    1983 ATC 70
    1986 ATC350X
    1986 ATC250R X 3
    1986 ATC200X
    1987 ATC200X
    2012 Polaris RZR
    ange's Avatar
    ange is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2003
    utah
    195
    there shouldn't be any "rust" in there because the metal in the cooling system (both the head and radiators) is non-ferrus.
    Anti-freeze, and non-distilled water will eventually cake up and leave deposits.
    Just scrape away what you can, as long as flow is not impeded you have nothing to worry about.
    Top end gaskets are ~$19 or so (check dennis kirk)
    KXT 250 A1/A2
    Warsaw, IL
    862
    Yea, its just some light type of corrosion/rust. I don't think it is blocking anything at all. I am stil learning more and more everyday about Tecate's, and 2 strokes. It is all new to me, and I wanted to make sure nuthhing was wrong.
    thanks
    1969 Trail 70
    1973 ATC 70
    1983 ATC 70
    1986 ATC350X
    1986 ATC250R X 3
    1986 ATC200X
    1987 ATC200X
    2012 Polaris RZR
