Results 1 to 7 of 7
Thread: 1985 atc 250 sx problem please help!!!
    Mar 2014
    quebec canada
    8
    Hi everyone , I am having a problem with my trike 85 250sx ... just finished redoing the motor new timing chain and centrifugal clutch bearing. When I started it up sounded like it did 30 yrs ago put it on reverse to get out of the garage . Put it in first gear and thats when my smile dropped lol it revs up but goes about 2 mph . I thinking mabee on the manual clutch, I tighted the springs too much or not enough .... in the manual im not to shure of the explanation can anyone tell me how to tighten the 4 springs/bolts ???? .... I got pics of what I found in the manual but not shure I understand spring torque rating .... if someone can help me it would be very appreciated thank you.
ID:	207062   Click image for larger version.
    Jan 2011
    Choctaw, OK
    2,755
    Follow the manual to adjust the clutch. The clutch bolts you mention get tightened to 7-9lbs. There is an adjustment on the clutch cover. Loosen the locknut, turn the screw CCW until resistance is felt then back the screw off CW 1/4 turn and lock it down. Try that and see if that helps.
    Mar 2014
    quebec canada
    8
    Great thanks for fast reply .. i baught a new clutch kit since disc were worn so might as well change em when i reopen it i will keep updated once its in ! Im pretty shure i have em tighter then that i put em in all the way
    Mar 2014
    quebec canada
    8
    So I put my clutch back in plates were totaled now I have another problem when thighting the bolt for manual clutch the top part cracked manual said 72-80 ft lbs I had it at about 50 .... so got new one ans now not even 40lbs snapped again !!! And starting to think throwin it off a cliff .... or the manual has wrong torqueClick image for larger version.
ID:	207595 so I snapped clutch center plate and on clutch pressure plate were the bolts go in it just broke off....
    Feb 2013
    Senoia, Ga
    635
    Quote Originally Posted by colombie420 View Post
    So I put my clutch back in plates were totaled now I have another problem when thighting the bolt for manual clutch the top part cracked manual said 72-80 ft lbs I had it at about 50 .... so got new one ans now not even 40lbs snapped again !!! And starting to think throwin it off a cliff .... or the manual has wrong torque so I snapped clutch center plate and on clutch pressure plate were the bolts go in it just broke off....
    Does it look like this?
    I did the same thing, only for me I had put to many of the discs, and plates in.
    You may want to check and make sure that you have not accidentally done the same thing.
    Mar 2014
    quebec canada
    8
    That is exactly how it broke how much ft/lbs do you torque ??
    Jan 2011
    Choctaw, OK
    2,755
    Me too!!!! did that got the tee shirt
