83-85 Honda atc 200x chain slider replacement 400ex
Hey just thought i would post my chain slider replacement .
Had an old beat up tm design 400ex chain slider that I cut the bottom piece off of and got to fit on my 200x (185sxr) and with a little trimming and a piece of pipe strapping I got to bolt right up.
The oem one is discontinued and no aftermarket companies make one so thought this might be useful to someone
Caution
Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
