Results 1 to 15 of 18
Thread: different brake drums for a honda 110?
    Pacific NW
    4,255
    I got the drum off and the shoes were melted.
    Looked like mud clumps and probably was some of that too.
    so I put on some used shoes and the adjuster was all the way.
    So I got new shoes and the drum won't fit over the shoes.
    Is there any chance that this trike has an odd drum?
    Maybe the 90 atc drums were smaller and this got pieced together?
    Thanks
    Attached Thumbnails Attached Thumbnails 110 brake.jpg   110 new brakes.jpg   110fullpic.jpg   110shoes.jpg
    Feb 2003
    Australia
    927
    No they are all the same. Make sure there is not a lip on the drum on the inside and near the outer edge. this lip will stop the drum going over new shoes and make sure the adjuster is backed off all the way.
    Pacific NW
    4,255
    Quote Originally Posted by greenhuman View Post
    Old shoes are about the same thickness but have NO idea why one fits but the other won't fit under the drum.
    I can't imagine a difference of .020" would matter that much.
    The old ones need to be adjusted all the way up to get very little rakes and the new ones are too thick.
    I get tunnel vision and need this sold fam emergency type.
    Outside temp in the teens doesn't help ether.
    Yupp, no drum lip and wire brushed with a drill so it's real clean.
    I've had drum lips prevent disassembly before but not this trike.
    Maybe missing an adjustment spacer?
    as I said, the old shoes were water soak melted into blobs so maybe
    time to check another machine that actually works.
    Maybe shoe lever got rotated in the past?
    but it sure looks in neutral, shoes parallel on the brake actuator. hmmmmm.
    wish I had a woodstove powered shop right about now.
    Apr 2013
    snyder texas
    456
    are they centering on the posts 2nd and 4th pics look as though lower shoe is offcenter some just a thought
    you know whats right therefore you know what is expected
    6,790
    Grab the shoes with your finger tips and lean them toward the drum slightly while your pushing the drum over the shoes . tap the drum on with a rubber mallet making sure their not to tight . I run into this problem all the time with all makes and models . Do not force them . Make sure the castings are clean on the new shoes at the pivots .
    Pacific NW
    4,255
    any idea what year this one is?
    no headstock sticker
    6,790
    If it has an aluminum rear carrier its an 83 model ... 84/85 have a steel carriers .
    Quote Originally Posted by tri again View Post
    Dec 2013
    Deer Park, WI
    53
    Is the shift pattern up to upshift or down to upshift?
    Pacific NW
    4,255
    Quote Originally Posted by Tri-Motor View Post
    I forget.
    but will check.
    Pacific NW
    4,255
    The different between the old and new shoes is about the thickness of a business card.
    I did shine up the round stud mounts of casting flash so that gave mew a few thousandths.
    The book recommends chamfering the outside edge of the new shoes btw.
    Whoda thought the book would have helped
    Old shoes would not adjust up and new ones seem perfect but as I said,
    both sets look identical thickness wise.
    Oh well, time to fix another one.
    Feb 2003
    Australia
    927
    You could file or grind down the flat ends of the shoes at the adjuster end to effectively close the diameter a fraction.
    Feb 2013
    chicago il
    505
    I have been there. On the horribly muddy and rusty ones I sand the drum with 60 grit sand paper until I see metal on the entire shoe contact area. Also make sure the shoes are completely seated top and bottom. Make sure the adjuster is loose and the pads are flat against the expander.
    Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
    Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
    Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
    KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
    Pacific NW
    4,255
    Steel carrier and neutral is all the way down.
    Wonder if they changed them so that getting on a running trike, you couldn't step on the shifter and go forward on accident.
    Dec 2013
    Deer Park, WI
    53
    Neutral at the bottom would be a 1985
    Dec 2013
    Deer Park, WI
    53
    I know Honda switched shift patterns in 85. I know Yamaha from 1982? and newer was neutral at the bottom and 12345 up
