Results 1 to 15 of 25
Thread: Another 250r Build.
    Jul 2012
    Joplin, MO
    597
    Another 250r Build.
    This story starts out when one day I was just out putting around my track with a friend and broke a piston. Now with the bike down and winter soon approaching, I thought about changes. I plan on doing some racing next year, what changes would benefit me? Shorter swingarm, small tires?
    I could go with a 450r swingarm, 04-05, that would get me an inch shorter and modern cheap parts. Shorter swinger, problem solved.
    Next up, tire options. What would give the widest range of tire options? Regular old axle? NO! Kart axle with almost infinite about of ajustments. But how could I get that to work? I got it, my good buddy Ed Bergman that went to Ashtabula, OH and kicked with his kart axle equiped Tri-Z!
    After lots of texts and phone calls, I had a plan. Time to start ordering parts. First the bearings.
    Wil they work?
    Yes they will!
    Test fitting.
    Ok, next problem. Stock shock and linkage. It will work, but if I get it as low as I want, the linkage is too low. Now what do I do? Ah ha, I have a 200x shock! Time to test. No go, too short. Hum? Ah ha, 350x shock will work! Now I am waiting on a shock, so to be continued………..
    Jul 2012
    Joplin, MO
    597
    Also with kart axle I can run bigger tires and paddles.
    Sep 2009
    Suring Wisconsin
    967
    That's some trick stuff. looking Nice.
    Rebuilding and riding trikes everyday and lovin every minute.
    http://www.3wheelerworld.com/showthr...light=pipeline
    Surprise, AZ
    2,428
    Rebuild, shorten and revalve the stock shock, I would do a spring mod as well.
    Jul 2012
    Joplin, MO
    597
    Quote Originally Posted by onformula1 View Post
    I may eventually get that done. But not wanting to spend the money on that right now. The 350x shock will work well enough for tt and ft.
    Blossvale NY
    4,563
    Pardon an ignorant question: whats the reason for wanting a shorter swingarm?? Seems like it would be a little tougher to control when going sideways through a turn?? I have never raced so I am clueless...just curious.
    Very cool stuff Steve!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Jul 2012
    Joplin, MO
    597
    A shorter swingarm moves the tires closer to your butt for better weight transfer for more traction. And a shorter wheelbase will turn faster.
    If a longer swingarm makes it harder to turn, a shorter one makes it easier.
    And as bonus, the 450r swinger is 3 lbs lighter
    Jul 2012
    Joplin, MO
    597
    I have a short track kit to help with slide control. This is a picture of it now. I am just fitting things up. You can see how much more the front tire turns. (That is not the front tire I am going to use)
    Jul 2012
    Joplin, MO
    597
    Haven't updated in a while.
    Jul 2013
    USA
    737
    What should the top speed be? I am thinking this is my favorite project to watch now! Hope to see some video of you racing this creature! Thanks for sharing, appreciate it.
    Jul 2012
    Joplin, MO
    597
    Top speed only needs to be a little bit faster than the guy behind me. Lol.
    tecaterob is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Miami Fl
    435
    Man I wish we had racing down here for that setup. Bike looks awesome!!
    3 86 Tecate 3
    1 87 tecate 3 (with kx 540 motor)
    1 87 tecate 4 (with 330 motor, 250r geometry)
    1 83 atc 70
    1 Kfx 50
    1 kfx 400 ( with 470 parting out bike)
    1 78 KZ 1000 ( with 1340 turbo)
    1 Aprilia SXV 550 Supermoto
    1 01 ZRX 1200 prostreet (sold)
    Jun 2009
    Leander TX
    2,217
    Nice looking trike Steve!
    Jul 2012
    Joplin, MO
    597
    I'm ready to put some paddles on it!
    Mar 2013
    Baldwin, Wi
    603
    Are you bringing it to Rampage?
    85 Tri-z Basket Case
