Results 1 to 2 of 2
Thread: Atc200 e Big red rear sproket ? 47t?
    Nov 2013
    New Zealand
    10
    looking at buying this
    http://www.ebay.com/itm/NEW-Honda-19...eb676f&vxp=mtr
    for a bike which came without the rear sproket couple of questions
    is this the only type of sproket for this model?
    and if i get it do i need to drill holes to attach it?
    thanks heaps
    Dec 2007
    Quebec,Canada
    1,014
    check on the microfiche, to drive this model of sprocket you need 2 plate and the rubber cushion.
    Be carefull if you don'T have the old sprocket,if I'm correct the axle that fit with this kind of sprocket have 5 mounting hole/stud, another similar axle use a different sprocket and only have 4 hole/stud........ if maybe someone ever changed the axle on your trike with a different one.
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
