The advancer is behind the points plate. It has 2 hinged arms with 2 small springs holding it to the main body. The springs often rust and break or disintegrate. Also make sure it moves. The main body is 2 pieces and need to move independent of eachother. They can rust and become 1.
Timing it is easy but download a manual. Either Kbonly or Oscarmayer have them for free. A regular automotive timing light hooked to a car battery is all you need. Hook the inductor ring around the spark plug wire and make it so the F mark on the flywheel lines up with the mark on the engine case.
Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
