Results 1 to 3 of 3
Thread: 110 Shift Slippage
    Feb 2014
    Holland, MI
    30
    110 Shift Slippage
    Hey guys,
    I'm a fairly new member of about a year now. I've got some really good tips through the new member discussion forum and I'm hoping to find the same here.
    So far this hasn't been too big of a deal but I thought I'd put something out there and see what comes back. I have a recently rebuilt 1983 ATC 110. I'll spare you the details because I replaced a lot of parts but more specifically to my current issue is that I replaced the clutch fibers and springs when I slid in a new shift shaft. I figured since I was going to have that side off I might as well. Per the manual I had I began running 20 W 50 Full synthetic for oil. I know it's quite a bit more slippery but with new fibers I wasn't too concerned with it. Now that it is winter here in Michigan on my last oil change I dropped down to 10 W 30 full synthetic because of the temperature. No more than a week ago I noticed I was having some trouble getting from first gear to second when at medium to high rpms. I noticed it again tonight. It does engage but it takes some coercing. I guess my question is would something like this happen from changing oils? Second part of my question would be should I forgo running synthetic altogether? I really appreciate any feedback that may help
    Cheers.
    Cold Lake, Alberta, Canada
    3,019
    I would definitely start with a conventional oil change first. See what that does. Did you soak your discs in oil before installing them?
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Feb 2014
    Holland, MI
    30
    Ok. That was my first instinct to change back to conventional. Yes I did soak them for 48 hours. I'll post again to this thread once I've changed it and had time to ride it.
    Thx!
