Thread: 350x rear master cylinder????
    Jul 2014
    Southern Illinois
    38
    ok, i just spent about an hour reading through some threads. i did not find a clear answer....so here goes.
    are there any rear masters that bolt right up and work with no mods? if so, which ones?
    if not, what will work and what needs to be done to it?? seems to me there should be a cheaper way than waiting to spend a 100 bucks or more on ebay if they show up there....
    heres a progress pick of my first build...Click image for larger version.
    85/86 350X - all dressed in black!
    84 225dx - 250 timberwolf swap complete!
    Van down by the river
    3,874
    Yes cr80 fronts are a direct bolt up.
    R.I.P. John Swinehart
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    Dec 2007
    Quebec,Canada
    1,014
    cr80 front master cylinder? on rear?
    Honda CB900 motorcycle is exactly the same.....only difference is the plastic elbow for oïl inlet.
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Dec 2010
    washington state
    681
    Thank you, thats good info
    GOT MUD?:
    devore,ca
    1,039
    A good option is an '85 -'86 250r rear master. The only thing you have to do is take a drill and remove the internal threads on the cyl mount. The 350x is threaded into the frame so you just need to remove the threads from 250r cyl to create the clearance for the bolts, the bolt centerline is the same. The 250r cylinders are more available and you can get the rebuild kits for them, where as the 350x not so much. You will have to use the push rod from the 350x cyl. I have heard of people using the rear master off a YFZ 450, that way you can even get rid of the fluid rezzi too, but I have yet to try that.
    I think "weezy" is thinking about the front CALIPER from a cr 80, not the master.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Jul 2014
    Southern Illinois
    38
    Well that's good to know bob marlin. Yfz option is interesting but I don't want to damage the powder coat to mod the frame. Anyone know if it bolts up?
