Results 16 to 30 of 40
Thread: Drive Chain Question 250r
    O.C., Oregon
    921
    Yep, o-ring master links are difficult to install, while x-rings are slightly easier, yet still difficult. If you're trying to install them in the cold of winter, it'll be damn near impossible, unless you heat up your o or x-rings. Try heating them up in some hot water next time, to get them nice and pliable. It makes them so much easier squish down.
    I have a motion pro chain breaker and it also acts as a press for master links. Best way to do clip style masters. It squishes the plates and leaves enough room to get the clip half way on before you have to remove the press.
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Jul 2014
    Lloydminster, Alberta
    503
    roostmaster, do you order that chain from rockymountainatv? it comes in a 520x120, is it okay to cut links out of an o-ring/x-ring chain?
    Mixing gas and haulin' ass
    1984 ATC 70 x2
    1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
    1985 ATC 250R-stock
    Mexico
    9,018
    This one works the same way, but cost a little more than the Motion Pro. Not cheap, but it's one of those tools that will last a lifetime if you take care of it. When I think of all the years I did my chains with a grinder and punch I feel like an idiot.
    http://www.ebay.com/itm/RK-Motorcycl...3c7c3a&vxp=mtr
    It sucks to get old
    O.C., Oregon
    921
    Quote Originally Posted by Samjp22 View Post
    Yes, I got mine from Rocky mountain in 520x120. I have an extended swinger so I needed the longer chain anyways. You can cut it just like any other chain, not a problem!
    2017 YZ 250x- Braap
    Quote Originally Posted by 250rRoostmaster View Post
    See the problem with that is when the chain is physically too thick, or the master link not wide enough, to compress enough to get the clip on. The last three times I've attempted to install the master link on my brand new O-ring chains, which was very recently and all three came with their own master link brand new included with the chain, I had to remove the O-rings from the master link and grind the chain down on both sides to have enough room to get the clip on. I'm not bullshitting and I'm surprised more people haven't spoken up. I was livid putting these things together because as everyone knows, a chain is only as strong as its weakest link, and here I am weakening my brand new name brand chains just to install them for the first time. It's something that makes me really, really angry. I seriously want to fly to D.I.D.'s headquarters and have someone install one of their master links right in front of me. How can they even sell a product like that which does not work? It's fricken bollocks is what it is! I get really revved up over it, no joke.
    O.C., Oregon
    921
    See the problem with that is when the chain is physically too thick, or the master link not thick enough, to compress enough to get the clip on. The last three times I've attempted to install the master link on my brand new O-ring chains, which was very recently and all three came with their own master link brand new included with the chain, I had to remove the O-rings from the master link and grind the chain down on both sides to have enough room to get the clip on. I'm not bullshitting and I'm surprised more people haven't spoken up. I was livid putting these things together because as everyone knows, a chain is only as strong as its weakest link, and here I am weakening my brand new name brand chains just to install them for the first time. It's something that makes me really, really angry. I seriously want to fly to D.I.D.'s headquarters and have someone install one of their master links right in front of me. How can they even sell a product like that which does not work? It's fricken bollocks is what it is! I get really revved up over it, no joke.
    I totally hear ya as the clip style are a joke and don't get me wrong, I've screwed up my fair share as well. The rivet style is hands down better and stronger and will save you many cuss words and thrown tools LOL.
    2017 YZ 250x- Braap
    Jul 2014
    503
    So on rockymountain do you order the chain then order which master link you want clip/rivet? Do the rivet ones just pop on or what? I've only ever dealt with clip chains.
    1984 ATC 70 x2
    1985 ATC 250R-stock
    O.C., Oregon
    921
    It comes with a clip style master link. You can buy either style separately which is what I do. You need a tool like the ones described earlier (motion pro or the one the el Camexican linked too) to install a rivet style because they need to be pressed together with a chain press.
    2017 YZ 250x- Braap
    Mexico
    9,018
    You need a tool like the one I posted to install the rivet types. You also need the tool (or a grinder) to remove them and when you do they should go in the garbage, but if you want you can try and reuse them, but it's not a good idea. With the right tool they are much easier to install than a clip and less prone to failure. The only issue is to not over tighten them, it takes the right touch and a little common sense. I use them whenever possible.
    NOTE: 250Rroostmaster types faster than me
    It sucks to get old
    Mexico
    9,018
    At one time I had a few thinner O-rings from ??? kicking around that were the same OD as the DID rings. I exchanged the fat chain O-rings for these and it suddenly became easy to get the clip on. That might be better than grinding a link if you can find some.
    It sucks to get old
    Grinding the link is necessary even with no O-rings installed at all. That's what I'm getting at. Master links that just are not wide enough for the chain. Never mind thinner O-rings, it doesn't work without any O-rings at all.
    O.C., Oregon
    921
    I've never had to grind anything on the chains i've installed, you must have angered the chain gods!! LOL I see what you are saying though if the dimensions are physically different between the master and the chain. That could definitely pose a big problem with assembly. I'm glad i haven't had to deal with that situation in my years of installing chains and hope you get some better luck with those masters!
    2017 YZ 250x- Braap
    This has been a great thread, thanks guys. I've only ever used master links so I don't have any experience with the rivets. Unfortunately I can't use rivets as I have to remove the chain on my XR too often for that to be feasible. I'll get an X-ring next time I'd say.
    Jul 2014
    503
    This thread has been very helpful! Thanks as well
    1984 ATC 70 x2
    1985 ATC 250R-stock
  15. #30
    Mexico
    9,018
    I've never seen one like that in my life. No wonder you're so pizzed!
    It sucks to get old
