Hello all,
i have an 81 110 ive been trying to rebuild, bought a big bore piston, high lift cam and larger carb. after putting the whole top end, together, i realized that a broken chain from one of the previous owners had cracked the case. ever since, i have pulled apart an older 90cc engine, which had a different case, and now i just pulled apart an 80 110 engine, and the cases look similar, but just slightly different. does anyone know if i can use the different case? will it mess with oil passages? as far as i can tell, any bolt holes look to be in the same place.
Thanks for the advice,
Elite
