I was wonderingif anybody could tell me how to use the timing chain tensioner.
Once it is back together and runing I will have pictures posted of the trike back together.
Service manual is a free download
Current rides
Taurus 650 (green)
85 250es big red
82 ALT50
82 ALT50
71 QA50
93 TRX 300 FW
Are you talking about checking / adjusting the tension on an engine thats all together, or setting the tension during chain installation?
1985 Tri-Z 250
1985 ATC250R
I have a real service manual and me and my dad just do not understand what it is telling us to do and my dad is a mechanic. But we are trying to do it during a chain install.
there is a bolt on the end if im not mistaken take that out then get a small flat head screwdriver poke it down the hole and go counter clockwise and it will retract!
73 atc 7084 ytm 200ern79 atc 70ytm 225 dratc 90
80 atc 110klt 250A84 atc 200es
85 atc 250es
Make sure that all the slack is on the tensioner-side of the chain when you slip it over the sprockets and line up the marks. Then, what the manual is probably failing to explain is that the tensioner is spring loaded, it will apply tension automatically as long as you "unlocked" it by loosening the bolt in the center. It will tighten the chain a little more if you do it again while the engine is running.
1985 Tri-Z 250
1985 ATC250R
