View Poll Results: what is a poll
Voters
0. You may not vote on this poll
  • change poll settings
    0 0%
  • change three settings
    0 0%
Results 16 to 30 of 33
Thread: I want some help with carberatur trouble.
    Jan 2015
    Beausejour MB
    51
    k ill let you know the results by the way do you know the settings for the air and fuel and float
    Jan 2015
    Beausejour MB
    51
    k ill let you know the results by the way does anyone know the air and fuel screw settings and also float settings for 1984 Yamaha 225 Trimoto carb
    Aug 2014
    South Louisiana
    1,915
    I want to say the air fuel screw needs to be 1 3/4 turns out for factory settings. I wouldn't try adjusting it without an air filter as that will be counterproductive. The link below has most of manuals.
    http://www.oscarmayer.net/atc/manuals/
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    glendive, montana
    1,822
    check your main needle, dealt with an issue like that before and found my main needle was wore, which was causing a fluctuation in my throttle. 1 3/4 to 2 turns out should be your starting mark for idle air mix.. Also those turns are with the air filter oil bathed will be different if you run it dry.
    Jan 2015
    Beausejour MB
    51
    K ill do that my needle is bent so maybe its going beside
    glendive, montana
    1,822
    there's your problem right there you need a new jet needle, or main needle which the manual says is a 5L10
    Jan 2015
    Beausejour MB
    51
    Does anyone know the factory air screw turns
    glendive, montana
    1,822
    factory is for the vm 22 carb 1 1/2. That is the stock carb for the 225 dx
    glendive, montana
    1,822
    the 225 drs which uses the vm24 carb is 1 3/4
    Jan 2015
    Beausejour MB
    51
    Maybe ignition
    Quote Originally Posted by muthey View Post
    Does anyone think it might be the timing or ignition or cdi
    it surges and that other advice didn't help much but maybe it's getting to much gas not sure how to adjust itthough
    Feb 2014
    Like to mention if the carb is anything like a Honda 200 make sure to check the adjustment nut on the carb cap where the throttle cable comes in. Mine got loose and made my 200s surge while idling, tightened it back up ran fine. But it could be carb cleaning issue.
    My ATC is faster than urs
    Jan 2015
    Beausejour MB
    51
    The cap isn't loose and i just recently cleaned the carb i tried starting it tonight and the first pull started and died rite away so im thinkin maybe cdi but maybe im wrong i don't know to much about fixing ATCs
    Six Stroke's Avatar
    Six Stroke is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central Minnesota
    315
    Start with a good tune-up first. Get a new air filter, spark plug, and set the valves. Also, make sure you don't have an air leak somewhere, like the o-ring that seals the carb to the manifold.
    Also, check out the petcock. Make sure it isn't dirty/plugged.
    1985 Yamaha YTM225DX
    2014 Yamaha WR450F
    2008 Yamaha TW200
    1975 Honda CB400F
    Dec 2014
    Montevideo, MN, United States
    7
    I had that problem too!! I had just cleaned carb, got it running and took it out to ride and had 1/2 throttle w/ backfire. Local mechanic said clean carb again, check air filter, and make sure rubber boot to air filter was on correct. I cleaned and put new boot on and worked fine after that ... GOOD LUCK!!
  15. #30
    Jan 2015
    Beausejour MB
    51
    Does the air filter need to be oiled? Should i ask a mechanic? Because mine has a new air filter i cleaned the carb do you think it could be the valves or timing? or some other electrical?
