Hello,
I've cleaned the carb twice, 2nd time I put a kit in it - new seals, jets (stock - 35 pilot, 82 main), and needles. Blew carb cleaner and compressed air through all carb body passages. Adjusted the timing. New air filter (oiled properly), not OE, but looks very similar with 2 different densities, gray fine inner, and yellow course outer. Have piece of radiator hose clamped between carb and air-box - seems sealed up - that's the way I got it. Sprayed carb cleaner while running to check for leaks. Ran it with the cas cap removed. It starts great, idles fine, revs up good at first, but if I start pumping / revving it will act like no fuel / kill if I let it. Ridding it with choke off, it seems good for the 1st part of the throttle, but if I continue to slowly give it gas, it cuts out. If I put the choke on (lever up) at that point it's back to life and running decent. I could just run it with the choke on, but that bugs me. These little Hondas are supposed to purr like kittens, but I'm out of ideas. Any help would be greatly appreciated - thanks.
