Results 1 to 2 of 2
Thread: 1985 350 x
    Jan 2013
    ol miss
    48
    1985 350 x
    IM thinking ive done about all i can do to the motor
    bored 12:1 ,Head work, cam ,swaped all electrics to 86 ,aftermarket ex cdi ,moded ex carb with a cobra pipe
    as of now im lookin for input on pipe and sprockets . and woundering about the main gears
    the amount of tork is impresive and would swap a lil for more top end speed
    curently running 22s on rear planing on droping to a 20 or even a 18 "seams a bit small to me still "
    any advice on the pipes would be awsum
    any input on whare to find 38 t rears would be usefull
    and if any body changed main gears for other ratios would love to hear about it
    thanks
    I think you'd do better with a 41MM FCR carburetor on that motor.
    Tires; 18's are great for MX but 20" tires suit me well for most trail riding on my 350X. You'll just need to order a rear sprocket from Sprocket Specialists to gain some more top end. I have a 14 front and you can run a 15 but forget the case saver at 15 teeth.
    Your exhaust is just OK, louad as hell though. I'd be looking for a 350X Supertrapp system with discs to add or remove......
