Thread: Uni outerwear for my 85 250r. need help!
    Ontario, CANADA
    4,538
    What type of outerwear do you guys use on you uni filter? All I can find is a kn style.
    http://www.outerwearsracing.com/products.asp?cat=11903
    Trying to find one for my 85 250r uni
    Thanks guys
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Marty is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2007
    Mesa, Az
    644
    If you are using a UNI filter you really don't have to use an outerwear. Foam filters are more absorbent to smaller or any contaminents in air. Now K&N are a different animal those flow air but hold not many air contaminants that is why outerwears are used on K&N filters.
    Ontario, CANADA
    4,538
    I've heard that as well. Just wanted to see if its possible. Headed to the dunes and want to be extra pre cautious. Thanks though!
    #NOLINK
    #SUSPENDTHIS
    Slidell, LA
    4,738
    I run one and its a custom job. You will need to contact a guy named Steve Geibel at Outerwears (I have pasted his contact info below). PM me your email and I will send you the graphic that I sent to Steve so they can create it. The cost is 34.95
    steveg@outerwears.com
    Aug 2004
    Ab Canada
    4,368
    Panty Hoooser!!...I just bring stuff to clean and oil my filter half way though the week, cant say i have had a sand ingestion related problem yet.
    1985 Tri-Z-
    Surprise, AZ
    2,428
    Just keep a spare, clean pre-oiled filter in a 1 gallon freezer zip lock and change when needed.
    Coat the sides of the airbox with thick wheel bearing grease, the sand/dirt will stick to it instead of the filter...mostly.
    Duning since 1979, never had a problem.
