Results 1 to 3 of 3
Thread: My 85 Tecate build
    Dustin87R is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2007
    Maysville, Georgia
    192
    My 85 Tecate build
    Well I guess it's time I start a build thread for this 85 T3 I picked up off of CL a few months back. It's pretty rough as you can tell but it's almost impossible to find them here in the south so when this one popped up I jumped on it. I was expecting it to need quite a bit of work but when I picked it up I was surprised to see how pieced together this thing actually was. The rear axle and master cylinder are from a Tri-Z the silencer is from a different bike and it's missing a lot of hardware. The engine would run but the intake boot was cracked and it needed some carb work. I replaced the axle with a spare I had and ordered an intake boot from Jeswinehart so I could ride it a few times before tearing it down for a complete restoration. While changing out the intake boot believe it or not I realized this thing had been running without reeds. John helped me out again by sending me a spare set he had and I finally got around to putting it back together this weekend. It will need some fine tuning but I'm very pleased with the way it runs for now. I've got a few other projects going right now so this will probably be a long build.
    Attached Thumbnails Attached Thumbnails 1125141704.jpg   1125141709.jpg   1125141704a.jpg   1125141704b.jpg   1124141706.jpg
    Jul 2012
    Seattle, Washington
    1,543
    If you are looking for some parts to complete this Tecate, I have a few parts you are missing. I've got all replacement plastics including the tank, radiator guard, light pcs, silencers, rear tires, and a couple aftermarket pipes.
    May 2007
    Maysville, Georgia
    192
    I'll definitely be looking for some plastics and aftermarket exhaust in a few weeks once I get everything cleaned up. I'll probably strip it down this weekend and get the frame, tripples, and swingarm ready for powder coating. I've already ordered new bearings from All Balls and I have a decent set of forks but I need to find a replacement rear shock.
