Results 1 to 3 of 3
Thread: Installing sprocket hubs
    Jul 2014
    Lloydminster, Alberta
    503
    Ok, after finally receiving my LSR +4 axle and separate sprocket hub I know have the dilemma of putting this hub on the axle. From LSR it's supposed to be pressed on, I don't have a press. Right now it's sitting outside in about -10 and then when it comes time to install it I'm going to heat the hub up a lot. Question is, better ways of approaching this? It would suck if I were able to get it on about half way and have it get stuck there. Any other suggestions are much appreciated. Sam
    Mixing gas and haulin' ass
    1984 ATC 70 x2
    1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
    1985 ATC 250R-stock
    Dec 2007
    Quebec,Canada
    1,014
    find a machine shop with a press........will take a little 2 minute and will save a lot of trouble
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Jul 2014
    503
    Okay going to have a shop press it on, does the hub pop or is there a certain distance it gets pressed on? If so could someone measure for me on an LSR +4 axle the distance from the end of your axle to where the sprocket hub is? Thanks
    1984 ATC 70 x2
    1985 ATC 250R-stock
