Results 1 to 15 of 18
Thread: 79 ATC90 no spark - timing chain off?
    Mar 2014
    Peoria
    23
    I just rebuilt the topend on my 79 ATC90 and now I have no spark. Set the valve timing, and points gap. When I was assembling the topend at one point the cam chain dropped into the engine and I had to fish it out, would this mess something up? Like now my flywheel T and F don't line up the way they should and that's why I don't have spark?
    Jul 2014
    KS
    104
    What do you mean they don't line up like they should?
    The cam lobes should be pointed towards the crankcase, valves should bothe be loose, mark on cam sprocket lined up with notch on opening, piston at TDC and T mark on rotor line up with notch on stator. If that is all correct then it is timed in relation to valves and piston. Bet you are 180 off.
    Mar 2014
    Peoria
    23
    What do you mean by this? Can you go into further depth
    Mar 2014
    Peoria
    23
    Nevermind I know what you are talking about to line up the T yes it is lined up. Ignition timing is set, valve timing is set, points gap looks good. Wiring all checked out. What else could I check?
    Jan 2011
    Brazil, Indiana
    2,087
    The timing chain has nothing to do with you not having spark. If your timing chain was off and everything else was correct, you would still have spark, just not at the right time.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Mar 2014
    Peoria
    23
    It doesn't seem as if any voltage is coming through the stator. I can hold the black wire and pullstart it and I don't get zapped. What would cause that?
    Cold Lake, Alberta, Canada
    3,019
    Now I'm a little worried that your troubleshooting the electrical by "feel". Do you have a manual and basic tools like a analog volt meter? I say analog because the digital ones don't seem to react fast enough to sense the quick pulse.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Mar 2014
    Peoria
    23
    I have a digital voltmeter no analog
    Jan 2011
    Brazil, Indiana
    2,087
    I should rephrase my previous post, the only way a timing chain can have any effect on you not having a spark, is if you forgot to put it in. You have something else wrong in your system. There is something you forgot to hook up, or hooked up incorrectly. The timing chain will only dictate when you get your spark. Hence the name.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Mar 2014
    Peoria
    23
    Quote Originally Posted by hoosierlogger View Post
    OK i've checked my points gap and ignition timing and they look to be perfect. Is there anything else I should check? I might just put the damn thing on craigslist I feel like i've checked everything
    Mar 2014
    Peoria
    23
    OK I poked around with a multimeter and found a shorted wire and finally got it fired up and running. Almost there, but now I have one last problem. When I start it up it doesn't want to run without the choke on. I'm assuming that would be a lean condition. I checked to make sure there weren't any air leaks and I'm sure there aren't, is there anything else I could check? I might just buy an eBay carb and call it a day, I'm sick of messin with the damn thing
    Mar 2014
    Peoria
    23
    Can I use a 110 carb if I get a new intake manifold?
    3,019
    Does it run better or the same as before the teardown? Stick with your stock carb. Clean it thoroughly and check the float height. Set your air/idle screw to factory setting too. BTW there's no guarantee the eBay carbs work any better; and it will need to be cleaned too before use.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Jan 2014
    La
    1,062
    I just have one thing to say there is no such thing as a 79 atc 90. in 79 they switched to the 110. so you either have a 77-78 atc 90 or a 79 atc 110
    Mar 2014
    Peoria
    23
    My mistake it is a 77. I just putted around on it today and it was running ok at first but then it started bogging out and backfiring out of the carb and exhaust. I do not have the stock intake, I am using an aftermarket eBay cone air filter. I thought I was running lean but I pulled the spark plug and it looked totally black so I'm not sure. Would backfiring be from a rich or lean condition?
