Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: 79 ATC90 no spark - timing chain off?
    Jan 2014
    La
    1,062
    Those cone filter do not work right out of the box with these three wheelers you have to jet your carb accordingly. To run correctly with stock jetting you have to have a filter like an uni or the original filter with the stock box to run correctly. This is most likely why your bike is not running right.
    Jan 2011
    Brazil, Indiana
    2,087
    Cool you got it running!!! What was the problem that it didn't have spark?
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Mar 2014
    Peoria
    23
    It ended up being a wire grounding out on the engine because the shielding was chewed up. Poked around with the multimeter and got it all sorted out. Does anyone know what size the stock jet sizing is? I don't see it marked anywhere. Are Keihin jets universal? Like any Keihin jet will fit? I'm planning on buying the next two jet sizes and trying those. Thanks!!
