Results 1 to 12 of 12
Thread: What goes the best in water?
    Dec 2014
    PA
    12
    What three wheeler goes the best in water, as in like river riding and such?
    Jul 2014
    Lloydminster, Alberta
    503
    250es and 250sx probably the best, can lift them and all that good stuff, next would be 200's. The best thing if you plan on deep riding is build yourself a snorkel and run all your vent lines up it, can go as deep as your snorkel will allow as long as you don't tip it over
    Mixing gas and haulin' ass
    1984 ATC 70 x2
    1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
    1985 ATC 250R-stock
    The Open Road
    4,736
    any machine with a sealed final drive is preferable along with a high intake and exhaust
    Jul 2014
    503
    yeah as chop said an exhaust stack also helps out a lot. With smaller displacement engines they don't produce enough exhaust pressure to idle under the water as an 800cc quad would. If you let off the throttle under the water it will most likely stall and then you could be sol
    1984 ATC 70 x2
    1985 ATC 250R-stock
    Feb 2014
    That's not true all my 200's will float in the water about 4 ft deep and idle all day. So back pressure on the 200's are fine.
    Jul 2014
    503
    And while its floating the exhaust is completely submerged? Cause my 300 fourtrax doesn't idle under water, hence why theres an exhaust stack on it.
    1984 ATC 70 x2
    1985 ATC 250R-stock
    Feb 2014
    Yes the exhaust was submerged. The only reason I have ever stalled in water was because of a cut in my sparkplug wire.
    My ATC is faster than urs
    Feb 2014
    Also check out the95jeepmonsta on YouTube there's a couple 200es a trx200es in a fairly deep gravel pit pond lol. There's a few videos and we also built a chariot to pull behind lol.
    Dec 2007
    Quebec,Canada
    1,014
    My sx did pretty well in water
    https://www.youtube.com/watch?v=g550Jr4pywQ
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    1986 ATC250SX FATCAT
    Jan 2011
    Brazil, Indiana
    2,087
    A boat is made for the water. A trike is not.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Dec 2014
    PA
    12
    My 200es didn't do to good, but my DX is excellent in water.
    Dec 2011
    Grand Rapids, MI.
    679
    You just better make sure that all your seals and gaskets are in good shape, it only takes water getting in one spot to mess something up.
    1986 KLT 185
    1984 200S
