Results 1 to 15 of 22
Thread: 1984 Tecate pics
    Jun 2006
    Utah
    91
    1984 Tecate pics
    I went to a friends house to pick up a really clean 1999 Sportsman 500 that I bought from him for $1500. He mentions that he has a 3 wheeler behind the barn that his boy used to ride (he's an empty nester now). He asked if I'd like it. Hey, never turn down a free trike. So we loaded it up and took it home. It's a little rough in some ways. The rear plastic is all busted up. The front could be restored I think. The tank is standard faded. It's got the original Dunlops on it I think. I started tearing the carb apart to clean it. Every thing I tried to undo, broke. Finally ordered a new carb spec'd like the Jimmy White book lists. I dialed down the main jet since the motor is stock. Runs like a champ. I had a really clean '84 250R. This thing is way scarier than the Honda. So, I've got a bit of work to do. Don't plan on a full restore, just make it a rider. Got the flywheel off and getting an encased one from jeswinehart on the way. Got the stealth black Maier plastic from eBay. The guy accepted an offer of $260 for it. Which was ok, but then I had to explain that purchase to the wife.
    I'll post a few more when we get it looking a bit better. I hate that the Maier stuff comes un drilled for the mounts. Looks like the grab bar is going to interfere with the fenders too.
    GB
    Attached Thumbnails Attached Thumbnails IMG_1335.JPG   IMG_1334.JPG   IMG_1333.JPG
    Nov 2014
    California USA
    77
    wow, you literally stole that thing;
    that bike looks to be 110% bone stock with every single orig part on it [except for the carb] that I can see.
    The grab bar is original.
    The tires may fall apart from age.
    The bike sat outside for 100 years, this is why the fenders disintegrated.
    If you buy a straight thru silencer, and jet it properly, it will run way better, but don’t throw the orig away.
    The hoses on the carb go under the metal clip on the back of the engine in case you didn't know.
    Apr 2002
    s.w. michigan
    6,498
    so that is the free one,,, wow ! That is what we call a score,,, wow.
    looks to have a reed spacer in there too
    Jun 2006
    Utah
    91
    Hey thanks for the tip on the hoses. I'd never seen a Tecate other than in pictures. In fact, I still haven't other than this one. I like that it is a little different.
    I cannot imagine this thing running hotter than it already does. I told my boy (16) that if he is even *thinking* about getting on it he better have a helmet.
    ~GB
    Nov 2014
    California USA
    77
    Quote Originally Posted by GeniusBlock View Post
    ~GB
    you're welcome
    yeah it will run better with a std silencer and it will actually rev even farther.
    i saw you were getting some type of jimmy white carb but not sure exactly what one that is but a carb that is 2 mm bigger than stock will be perfect if you run it without the silencer . . anything bigger will cause it to have a bit less bottom end . . the stock carbs actually work really well especially if you are wanting bottom end power . . anything else will reduce bottom end.
    if you do not use the lite, i would remove it . . it will be the first thing to hit your head on or break if you crash.
    check the torque on the swing arm pivot bolt and rear carrier bolts periodically . . they can come loose.
    is your orig rear shock missing or bad? . . you can get them rebuilt.
    the site below has some new old stock inventory if you need something you can't find.
    http://www.xtremeusa.com/
    oile's Avatar
    oile is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2012
    kansas
    600
    An Jemco pipe/silencer performs very well on 84/85 Tecate's and you can still buy them new.
    Jun 2006
    Utah
    91
    Not sure how to tell if the old shock needs rebuilt or not. It seems ok. It's a little soft but I'm 6'2" and about 220. I haven't checked the swing arm bolts yet. Good tips.
    Thanks for the info.
    Here's the other side of the beast.
    ~GBClick image for larger version.
ID:	208717Click image for larger version.
    Jun 2009
    Leander TX
    2,217
    That's a great Tecate - has the skid plates and the fender brace and the lights. Nice find.
    Jun 2006
    Utah
    91
    This is right after we got the new carb installed. It didn't start on the first kick...about 10 or so. Clutch plates were all stuck together. You can tell when my son put it in gear.
    Nov 2014
    California USA
    77
    no problem . . Ok, well there’s a couple options for this . . it may be that the shock is ok, they were not designed for riders over around 180 lbs people so kawi sold an optional heavy spring . . also, the 84 bikes had a bottoming out problem which was improved in the 85 model . . below are the p/n’s for the springs but they are pricey and hard to find . . you also need to look at the vin number stamped on the steering head to verify what year it is so you get the right spring if you find one . . they are incredibly rare and you are not likely to find one on ebay either.
    the site I posted shows them as available but I wouldn’t hold my breath . . it also may have leaked the gas out . . if you remove the spring then push down on the shock and it returns by itself it has gas . . if you need it rebuilt one place that can do it is posted below but I can’t get the link to work so they may be out of biz . . of it just needs gas you can get recharged at most bike shops.
    There is a damping adjustment knob on the top of the shock that can firm it up a bit too.
    I think there is also a shock from another bike that will fit but I have never tried this.
    shock rebuilders
    http://www.suspension101.com/
    these guys may be able to do it also.
    http://www.racetech.com/page.aspx?id=56&menuid=62
    http://www.partzilla.com/parts/detai...2081-1736.html
    92081-1736
    http://www.partzilla.com/parts/detai...2081-1857.html
    92081-1857
    Nov 2014
    California USA
    77
    If the front is too soft also, you can run heavier fluid like 15 wt and the level 5/8” higher than stock.
    You can also preload the springs an additional 3/4” with a piece of pvc pipe . . get the front wheel off the ground, loosen up the top pinch bolts on the forks, put slight pressure on the fork tube as you remove it because it is preloaded a little . . if its still too soft and you have air fittings on the top of the nuts, you can add some air . . less than 10 lbs should help . . if you don’t have air fittings you can buy them for a couple dollars then tap your nuts and install them with some silicone sealer . . you can also buy different front springs . . I don’t know if these are heavier or just different.
    You can also have both front and rear springs custom made from eibach . then can calculate/estimate what you need.
    You can also preload the rear spring a bit . . I would try around another 1/2” – 5/8” . . put the rear in the air, clean the threads off the shock, spray some wd40 on them and on the top of the spring, then you can loosen the bottom nut on the spring with a drift or big flat blade screwdriver etc . . once its loose you can turn the spring and if you are lucky, the nut will turn with it . . if not you can take the spring off if needed.
    https://www.denniskirk.com/harley-da...250-tecate.mmy
    http://eibach.com/america/en/powersport/products/atv
    Jun 2006
    Utah
    91
    Sweet! Thanks for all this. It is much appreciated.
    Sep 2005
    MICHIGAN
    2,027
    Some people put a 300ex or banshee or raptor rear shock on theirs.
    Check out this thread:
    http://www.3wheelerworld.com/showthr...ap-Interchange
    You got a great deal on a Tecate !!! It is nice shape and already running !
    Used parts for 84/85 are easier to get, and it doesnt look like you need much.
    Maybe you just need to adjust clutch cable?
    86 T3
    84 T3
    86 KX250
    emmie357's Avatar
    emmie357 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2013
    Upstate NY
    214
    I have a 300ex shock on my 85, very happy with it... easy to install, and can be found cheap.
    84 YTM200E "yamahauler"
    85 YTM200
    85 KXT250 Tecate
    Apr 2003
    Central New York
    1,860
    84-85 Rear Shock options go original or go Honda 300-400 ex? for ease
    300-400ex shock installed on mine after I rebuilt and restored my original then swithched to a raptor rear then installed the Honda rear shock. No good and no where to mount res due to short line for the raptor. You can grab a Honda shock off e-bay like new for pretty good price. I think it mounts upside down? I have 2 original tecate rear shocks, one rebuilt, polished and powder coated and one all stock. If you want to stay stock im looking to dump them as Im gonna stick with the Honda shock out of ease and the mount on my from is busted off. I had the one totally redone and beautified yet it still leaked so I just went to a more basic rear shock after the raptor shock drama.
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
