Fabio here is a cutaway. It's a pipe with holes with a bigger pipe on the outside.
Belay my last. That does nothing.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
Definitely looks like a silencer. Again, I am not an expert, but I do find this stuff interesting. It is a larger volume which decreases pressure. The sonics are much different than a two stroke as stated above by others. I believe in a two stroke you are looking for sonic shock waves which occur when a gas is traveling at the correct speed with respect to the nozzle diameter to create a shock wave. Wave placement get much more complicated with sonic velocities. I do not know what the exhaust speeds for an atv range to, nor do I even have a guess, but I am guessing that on a four stroke they are not looking for that type of wave as, was stated above, the exhaust valve controls the combustion chamber. However, the mass flow rate of a compressible gas is temperature dependent and an expansion creates a temperature drop. To maintain flow rate of a cooler gas, the velocity must increase. To increase the velocity, without increasing the temperature, the "nozzle", or diameter must again be reduced. Again, those that apply this practically would be better suited to elaborate as I am simply going from scratch. My experience is that the people that design things start with a better understanding because those that came before them in their field already did the ground work and established baselines. But yes, looks like a silencer, walks like a silencer......
nstyle73
"When in doubt, wind it out"
Feedback: http://www.3wheelerworld.com/showthr...k-for-nstyle73
On Suzuki and Yamaha inline 4 sport bikes they have a valve in the exhaust that opens and closes with rpm range. This sends the sonic waves back at the correct moment to hold the fresh mixture in the cylinder during overlap (when both the intake and exhaust valves are open at the same time). There is significantly more overlap on a motor that makes high rpm power than a little torque motor that all trikes have. Being that they are putting these on DOHC hi reving new 4strokes I can see why it works. The expansion chamber is basically the same idea.
85 Tri-z Basket Case
Info for the bike from the original post.
This is from- KTM via MXA.
It may look like a two-stroke expansion chamber, but it actually a stylized resonance chamber that fits over the existing head pipe. KTM calls it FDH which sounds like a florist shop. The 250SXF Factory Edition has the old school tube-style resonance chamber.
New Flow Design Header (FDH) with an integrated sound resonator that is also designed to increase power along with a new lightweight silencer that is 40mm shorter than the previous design for quick throttle response.
This is from- KTM via Dirt Rider.
The exhaust is new on both bikes, but different. Both machines have a different head pipe and their muffler is now 40mm shorter. The new exhaust moves the muffler a total of 60mm closer to the center of mass (forward). With internal muffler changes, the new muffler is also said to be quieter. [A quick editorial note: KTM is great about making sound-responsible bikes. This goes a long way toward improving the sport for everyone. Thank you, KTM, for your approach to bike sound.]
50 – the bulged 450 head pipe is called a Flow Design Header (FDH), and it looks wild. It basically looks like a small two-stroke expansion chamber, and is designed to improve power and throttle response while helping reduce sound.
It sucks to get old
I'm definitely not an exhaust scientist but here's some general info.
The bulge in the pipe on the bike is a simple “resonator” as was mentioned . . Some cars came with resonators from the factory . . the 65 thru 68 dual exhaust mustangs had them.
“In a Helmholtz resonator design, a cavity is attached to the exhaust pipe. At a specific frequency, the cavity will resonate and the waves in the exhaust pipe are reflected back towards the source. However, there are also pass band frequencies where the resonator has no effect and so resonator muffler design is targeted to specific frequencies where the majority of attenuation is required. In some designs, the muffler has several resonators of different sizes to target a range of frequencies.”
This article below discusses sound waves to some degree and the chamber attached to the pipe in the photo which is referred to as a “helmholz” design or resonator .
http://www.paraglidingteam.nl/PPGTec...1155795969.pdf
“The theory of Helmholtz resonators is used in motorcycle and car exhausts to alter the sound of the exhaust note and for differences in power delivery by adding chambers to the exhaust. Exhaust resonators are also used to reduce potentially loud and obnoxious engine noise where the dimensions are calculated so that the waves reflected by the resonator help cancel out certain frequencies of sound in the exhaust.
In some two-stroke engines, a Helmholtz resonator is used to remove the need for a reed valve. A similar effect is also used in the exhaust system of most two-stroke engines, using a reflected pressure pulse to supercharge the cylinder (see Kadenacy effect.)”
http://en.wikipedia.org/wiki/Helmholtz_resonance
”The outer chamber in the Powerbomb allows the air to expand, cool and ramp back up at a higher velocity.”
I’m not saying their design serves no purpose but this portion of their explanation is not exactly correct . . cool air is more dense than hot air and will move more slowly thru an exhaust.
The purpose of the exhaust is to exit with the highest or the most optimum velocity possible combined with enough flow so it does not cause reversion . . if the exhaust exits with sufficient velocity, it will help pull the air/fuel mixture into the combustion chamber thereby creating a cleaner and fuller charge . . these things occur because the intake valve opens before tdc while the exhaust valve is still open which closes after tdc. . these two timing events are what is called “overlap”.
If you remove the exhaust from a 4 stroke [and 2 stroke but their system is obviously different] if will loose maybe 60 -70% of its power and it will only rev to less than 1/2 of what it would if it had a properly tuned exhaust . . I’ve done it on more than one occasion, lol.
If you put a 1/2” diameter pipe on an engine that needs a 1” one, it will impede the exhaust flow which will thereby reduce the intake flow plus more exhaust will remain in the cylinder contaminating the intake mixture reducing its effectiveness.
Once an optimum size and length pipe is determined for a particular set up, both reducing or increasing the size will change the power characteristics.
It’s partially a case where bigger is not better . . I have seen a lot of people change their exhaust only to lose overall power.
When one talks about “backpressure” it is the same as talking about exhaust velocity and volume . . if you reduce the exit size of a properly tuned exhaust pipe by around 50%, it will significantly reduce overall power and peak rpm as well as a few other "unbeneficial" things.
High end multi cylinder headers also use merge collectors . . in some racing apps, headers that have one or two larger tubes attached to the tube exiting the head are used . . these are referred to as “stepped” headers.
Dyno tests on different header sizes . . the biggest headers reduced overall power.
https://www.youtube.com/watch?v=O1bXPNy1Yn4
dyno tests on different collector lengths
https://www.youtube.com/watch?v=1ywUEz5XtdE
Excellent post and the most helpful thus far for me personally. Thank you.
Not just old Mustangs came with resonators from the factory. They may have been amongst few that came from the factory with ONLY resonators (glass packs), but the truth is most cars come with resonators these days right from the factory but they are incorporated with the entire exhaust including the cat(s) and muffler(s) in order to control "resonance". If you're not familiar with that word, it's that really powerful drone that is at that "just right" frequency when you're cruising in your vehicle under a mid to light load. It's a low frequency but it's loud. A lot of times it will be especially pronounced with an altered exhaust system in any car or truck. I worked for many years at a custom exhaust shop that really pushed Flowmaster, and we had a fair amount of people come back complaining about that "drone". Sometimes we'd try and swap the muffler out from a 2 chamber to a 3 chamber, or a 3 chamber to a big-block Flowmaster, but many times we'd end up installing resonators in addition to the mufflers.
As a kid I was always fascinated by V8's with glass packs. The trend has been somewhat passe for many years now, yet I never stopped using them. I've always used glass packs (resonators) on my V8 gas engines and I always get tons of praise, yet not many other people do it. The rasp they give, I've never been able to explain but the above post has helped me understand it. A healthy V8 at WOT with glass packs is just such a piercing sound, it forces you to hear it. You look to see what that noise is whether you love it or hate it, but you can't not look.
I have learned over recent years the huge effect exhaust has on both engines and wood stoves, to reference that again. The fact is that exhaust has a lot to do with the combustion process, which obviously happens before the exhaust comes into play, might seem odd at first. It is still fact however. I think knowing now more about what that rasp is that glass packs produce I might find it a little more likely that these little resonators are doing something. KTM is a pretty stand up company as we all know, it ain't Kimco or whatever the fork. I'm guessing they know a thing or two more than us on this particular front, although obviously we're still smarter, but I'm willing to bet this wasn't done without plenty of research and money spent. I bet the gain isn't huge, but there could be a gain. Not to mention, if a gain were found with something like this, even a small gain, it could be the infancy of an idea that might lead to a 30% horsepower gain as this technology evolves. Stranger things have happened.
good thread. i've learned a bunch. i'm sticking with science on this one though. floating valves or not, a four stroke is not a two stroke. this pipe is not supercharging the chamber of a valved engine at any rpm. exhaust flow is important. vacuum pressure, air speed, restriction, flow, etc, etc, etc, are all factors that must be managed. i would never argue against that. that being said, i cannot understand how the design in this bike increases performance. it makes the bike quieter. if KTM's argument is that this bike has a 3-5% increase in tourque over an equally quiet comparable bike because of this "megabomb" then i'd agree. but that is semantics. the "equally quiet" is the qualifier. it is just double-speak for "we can make your fast bike quiet". That is my position. One thing to consider, in KTM's favor, are federal noise emission restrictions that apply to manufacturers across the board. If any stock bike produced had to be within federal noise guidelines, and this particular bike would allow for more power while still maintaining the noise guidelines, then, I suppose, this is a performance enhancement. But, if you replaced the "megabomb" with a conventional pipe the only change would be sound, IMO.
Wubba Lubba Dub Dub!!!!!
TRIKES:
86 250r
85 250sx
86 250sx
85 Yama 225DX - The Rental!
150cc Piranha powered 70
110cc Lifan 70
82 70
83 ALT 50 Trail Buddy
88 Yamaha BW 80
84 z50
Good post Aramid!
But like Redsox, that point where they talk about it's noise reduction catches my attention. So now that it's being called a resonator, and resonators seem to be more about sound than anything, I think you guys are right. It's starting to look like it is a way for them to make a higher performing exhaust while still keeping it within noise limits. Also noted how they talked about that design allowing them to change the silencer position for better weight distribution..
Interesting topic for sure.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
thanks ride red and Fabio and thanks redsox for the info . . I think redsox is correct and it is the same thing I was going to post last nite in reply to fabios post but I hit the wrong button on the computer and it quit working so I am on another computer and need to find some 12 year old to fix the other one, lol.
just another bit of fun info you guys may already know but here it is for some others . . neither air nor water like to bend . . it will flow thru a straight pipe faster than it will thru a bent pipe . . putting a bend in a pipe to go over the rear axle on a vehicle will slow it down slightly . . this is the same for 2 stroke pipes also, plus sound waves are round by nature . . when you change their shape it alters their nature such as sound and sped etc and since sound waves are merely pressure waves, they affect exhaust flow also . . there was one test done on a 2 stroke pipe where a pipe was made that exited straight out of the cylinder and had no bends and a second pipe was made of the exact same proportions with bends in to fit the bike and the one with bends did not work as well overall.
this goes for intake and exhaust ports also . . if you look at ultra high perf auto cyl heads where room is not a concern, the ports are made as straight as possible . . also, velocity stacks are often used partially to eliminate the bends in the conventional intake manifold . . in addition to the comment made by a few regarding sound waves affecting flow/perf, tpi which as some know means tuned port intake or tuned port injection means that every runner is the same length and is also tuned to the engine buy having a specific length.
without going into much detail, there are pressure/sound waves in an intake that travel at ultra high speeds back and forth from the intake valve and they want these waves to be going into the intake valve just when it opens to help bring the fuel mix into the cylinder . . the problem is that these waves are apparently maybe 14 feet long so since it would be a bit impractical to make a 14 foot long intake, they divided the length of the wave by even quarters until the number was short enough that they could use it for an intake runner length . . this process is similar to cb radio antennas and i'm guessing other antennas as well, but this science is a bit beyond my pea brain ability to really understand no matter how hard I try.
as far as it applies to exhaust . . it is apparently similar which is why a certain collector length works best on exhaust as I think nstyle mentioned ut it is complicated in a different way where the sound/pressure wave exiting the pipe affects the exhaust so not only does changing the length of the pip affect performance, on a 4stroke at least, the shape of the exhaust exit also affects performance and this gets into megaphones as another here mentioned . . in short, the taper of a megaphone affects power . . it basically takes x amount of power and spreads it over a slightly wider range, therefore, they do not really make additional . . one poor way to explain it would be to imagine you have a spoonful of butter [the butter will represent the total amount of horsepower] and you place it in the center of a piece of toast, and you eat the toast, when you get to the butter you get a whole bunch of it all at once . . if you spread the butter evenly over the entire piece of toast, you still have the same amount of butter but you get an even butter favor with every bite but you never get a bunch of flavor all at once . . another example might be a tecate vs a Honda . . both are excellent bikes. and both are fast, but anyone that has ridden them both in box stock form knows the Honda has a nice smooth predictable power delivery and the tecate...well not so much, lol, but I like them that way.
if one is drag racing or dong the dirt track mile etc, their engines are operating over a narrow rpm range and at the top of the rpm range, so to take some of this power and spread it over a wider rpm range than the vehicle operates at is pointless and will make the vehicle slower for the purpose it is intended for . . conversely, taking an engine with a narrow power band and trying to use it in a motorcross bike simply won't work very well.
