Thread: 250 big red engine help????
    May 2013
    ontario
    Angry 250 big red engine help????
    Hello everyone, I have a few questions regarding my 250 big red engine, anyways I bought this engine a while back and polished it up to throw into my trike, it started and ran fine but it smoked like something sick and ticked pretty bad! So I took the top end off to swap piston rings and timing chain only to notice a bottom half of my piston has cracked off, I found a decent size peice of it in the screen down in the bottom. I wiggle the crank arm to check for play and there isn't any what so ever, but if I grab the right hand side of the crank I can feel a little budge,but hardly any to notice, so my question is do you think this engines junked although it ran fine? Should I work with it or toss it? Thank you in advance!!!
    Nov 2014
    California USA
    77
    can you post photos?
    if it ran fine before, it will run fine again.
    the noise could be from piston slap especially since the piston skirt is broken or from too much clearance on the rocker arm.
    it is also possible that the cam is going flat . . if the cam looks perfectly smooth on the top of the lobes it is likely ok.
    i would guess the cylinder is worn enough to need a rebore . . you can measure it to see.
    put carb cleaner in one port at a time on the cylinder head then look at the valves . . it it is wet around the valves, they are leaking slightly.
    May 2013
    ontario
    These are a few pictures I took, I assumed it was the timing chain making the sounds because even with the adjuster pushed all the way in, I could probably of knocked the chain off with my fingers lol,and I'll try that with the valves! thanks for the reply! Any more info would be greatly appreciated!
ID:	208874   Click image for larger version.
ID:	208875   Click image for larger version.
ID:	208876   Click image for larger version.
    Dec 2014
    Hoffman Minnesota
    135
    Yeah if your a good enough mechanic do the crank bearings and just put in a new piston
    1982 big red
    1974 atc 90
    Life is hard, but its harder if you're stupid - John Wayne
    Ragar is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2015
    Eau Claire WI
    186
    That Cylinder Isn't looking healthly at all from those pictures.
    Can you feel the scored areas? at the very least It needs a hone, if not bored and honed.
    The hard coat on that cam is gone. you can see where the bare metal is corroding due to the lack of the hard surface.
    If the oil had a metallic flake to it, your bearings will need to be replaced due to contamination.
    Greenville, TX
    137
    I agree with Ragar. Personally I would bore the cyl and that cam def needs to be replaced. If it's not already going flat it will be soon. Sounds to me like it's hot rod time. Step up the wilder cam and a dome piston, presto you'll have a nice souped up engine. If I have to tear an engine apart I never like to put it back together stock. May as well upgrade while your in there.
    Currently Own
    '85 Honda Big Red 250es
    '84 Honda Big Red 200es
    '81 Honda ATC 185s
    Unk yr Adventure Vehicles 3 wheeler
    Aug 2014
    South Louisiana
    1,915
    Another member Mickey Dunlap offers 349cc big bore resleve for the 250es/sx.
    http://www.3wheelerworld.com/showthr...c-big-bore-kit
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
