Results 1 to 15 of 16
Thread: 85r rear caliper question
    trikeguy2014's Avatar
    trikeguy2014 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2014
    Indiana
    158
    I have always had pads put on by my mechanic. I realized when I pulled my caliper apart last time to grind off where my rotor is little short so my pads wear until the top hits and will not close any further. Anyway a brake caliper on these trike have a two pin system. On mine it has a hook on one side and a hole on the other. Only pads I can find that look the same on the Web is front pads from trx 250r. Has anyone ever made this conversion... The previous owner must have changed mine to this... I can post picks because I'm not 100% sure that it is a caliper from the front of a trx 250r. It looks like one but I don't know if it would mount up right...
    One of the Haspin Locals
    Trikefest 12' 13' 14' 15' 16' 17'
    Trikes owned
    1985 Honda atc 250r - raced by yours truly #27
    1985 Honda atc 250es big red- Dad bought new from Ike's Honda in Richmond Indiana
    1984 Honda atc 200s - raced by Evan Pflum #3
    O.C., Oregon
    921
    ATC250r rear pads are like you describe, a hook on 1 end and a hole on the other... Like these from RMATV...
    https://www.rockymountainatvmc.com/p...d-Metal?v=1250
    EDIT- This is wrong... See below..
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Mar 2014
    Indiana
    158
    Yeah that's what they look like... This is what I ordered and realized they were not the right onesClick image for larger version.
    Trikes owned
    O.C., Oregon
    921
    Those are for the front caliper
    2017 YZ 250x- Braap
    na
    5,702
    Quote Originally Posted by trikeguy2014 View Post
    These fit the front and rear. Been running them for years. The ones with the hook are for the trx front calipers. Sounds like you have a non OEM caliper ..
    http://cdn.partzilla.com/diagram/hon...HA28F/1100.png
    Proudly NOT a member of
    "Team on the Teat"
    Mar 2014
    Indiana
    158
    Yeah I thought the ones with the hook were trx fronts... All the ones I find one eBay and Amazon are just like the ones i showed... Somehow I have trx fronts caliper on the rear of my 85r... PO must have did that... Also explains that my mechanic raced trx 250rs for years probably the reason he had the pads for it in stock
    Trikes owned
    London, Ontario, Canada
    1,059
    ^^^^ Agree, My front and rear are the same, with two holes for the pins. 85 R BTW
    Ross..
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    1985 Green Tecate Sold
    My Wife's Ride
    My Kids Ride
    O.C., Oregon
    921
    Yes, I am very wrong on this... I apologize for my misinformation. What I failed to remember was that I have a front caliper off a YZ250 on the rear of my R which in fact use a similar style with a hook end. Listen to Mosh on this one.
    2017 YZ 250x- Braap
    Mar 2014
    Indiana
    158
    Heres what I have and the pads I ordered... Not going to work for rear going to order trx fronts and use those I have for the front wheel when mine wear out u guess Click image for larger version.
ID:	208976Click image for larger version.
ID:	208977Click image for larger version.
    Trikes owned
    Las Vegas, NV.
    2,531
    I realized when I pulled my caliper apart last time to grind off where my rotor is little short so my pads wear until the top hits and will not close any further...
    Your brake rotor isn't too short, it's having the wrong caliper on there that's causing your loss of rear braking power.
    Mar 2014
    Indiana
    158
    I just take a little air grinder to it when they touch... The brakes work very well so I will probably keep the setup for now... The good thing is trx fronts come in sets of 2 for around the same cost as one set of rear pads
    Trikes owned
    Las Vegas, NV.
    2,531
    Based on the remaining shape of the pads, that the rotor doesn't touch, just grind that portion all the way down to the metal backing plate, then the 2 pads will never touch again. That's a nice 2 for the price of 1 deal there though.
    na
    5,702
    So what is holding the caliper from rotating forward if it is an 85 swingarm? Is there a stay rod connected from the caliper bracket to the swing arm? Got a side view pic?
    "Team on the Teat"
    Mar 2014
    Indiana
    158
    Yeah the caliper is connected to a brake stay... I'll grab a picture tonight
    Trikes owned
    Mar 2014
    Indiana
    158
    Side pic
    Trikes owned
