Page 10 of 21 FirstFirst ... 8 9 10 11 12 20 ... LastLast
Results 136 to 150 of 312
Thread: Tri Z Engine Build
  1. #136
    Mexico
    9,014
    Quote Originally Posted by Bren_downe View Post
    "Ozzie" should read Ozzy. We don't want the prince of darkness after you guys…
    Good thread. Carry on.
    Dangit! I thought it was, but "aramid" spelt it Ozzie, so I did the same (Never bought the CD) Oh well I have an edit button, so I can fix it
  2. #137
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by YTZ drew View Post
    Nico, this is an awesome thread, and an amazing build. Your work is outstanding! And Barnett, you sir are a genius! Why didn't I ever think to use a CD? Great idea.
    Thanks for the generous words, although I doubt I am that worthy . . I actually don't remember how I got the idea so I can't claim credit for it, not that I really care anyway, mainly because they don't offer a set of steak knives with prefabulated amulite blades and finely crafted, artisan designed, faux wood handles and a four place setting of monogramed paper doilies for good ideas here.
    Actually, I do [or did] a lot of chamber measuring because I build high perf engines for street cars and thought there must be a better plate that’s easier to work with for motorcycles.
  3. #138
    Jan 2013
    minnesota
    5,911
    咬我 。。哦,我想你的山羊是最美丽的
  4. #139
    Mexico
    9,014
    咬我 。。哦,我想你的山羊是最美丽的
    "Bite me . . Oh, I think you are the most beautiful goat"
    Damn, you better stick to the English menu the next time you order Chinese
  5. #140
    Jan 2013
    minnesota
    5,911
    lol, I actually typed in "bite me . . I think your goat is most beautiful" . . I must have used the same bad language translator that lindsay lohan used to translate arabic, but yeah, after seein the translation you got..i think your right, i might end up with some anatomical part id rather not eat if i use it.
  6. #141
    Terryville,CT
    1,616
    hey that's my black Tri-Z now when was still running it! in the bottom video those where the days! lol
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
  7. #142
    Mexico
    9,014
    Quote Originally Posted by tri-Z ripper View Post
    You lost me partner. What video and what Tri-Z?
  8. #143
    poolieZerUK is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2013
    Hartlepool UK
    150
    Made up an etching of the ports of a tri z barrel.
    I have not ran it so can't comment on performance, but it has been ported and it looks to be good work.
    Exhaust port is 58mm wide x 37mm deep and 35mm from deck.
    Expecting more top end!
  9. #144
    Surprise, AZ
    2,428
    ^ That's a wide exhaust port for a cylinder with no bridge, I hope it works out for you.
    Sent from my SM-G386T1 using Tapatalk
  10. #145
    Jan 2013
    Hartlepool UK
    150
    The motor it came from was off ebay bought for the crank cases.
    It had been snatching the rings but the bore and piston were fresh, there was no chamfer round the ports which I had put down to poor workshop practice.
    I added some chamfer and it runs smooth so was going to give it a try.
    It's on it's penultimate bore so I guessed it must have been ok prior to last re bore?
    Worth a punt as it came with fresh rings?
    But I appreciate what you are saying.
    Mexico sorry for nicking some of your thread
  11. #146
    Surprise, AZ
    2,428
    Quote Originally Posted by poolieZerUK View Post
    70mm bore?
  12. #147
    Mexico
    9,014
    I don't think you are measuring it correctly. If is was truly 58mm it would be into the transfer ports. The measurement is to be taken straight across the port map with the map wrapped around the piston, NOT flat as I suspect you have it when you get 58mm. All other measurements can be done flat, but the horizontal measurements are to be done across the arc.
    You also want at least 6mm between the exhaust port and each of the transfer ports, or something bad happens with the flow. Maximum exhaust port width on that jug with a 70mm bore would be about 49mm. If it's bigger than that you'll be too close to the transfers and the rings might catch.
    No I am not an expert on this topic, but I have been reading about it for months and I did stay at a Holiday Inn Express a few weeks ago which means nothing to you on that side of the pond, but believe me it's critical to this topic.
  13. #148
    Jan 2013
    minnesota
    5,911
    I am not an expert on this topic, but I have been reading about it for months and I did stay at a Holiday Inn Express a few weeks ago...
    If that was in Mexico, wouldn't it be called "Vacaciones en Express", or did I just did I just say that I would like to have a quick vacation with your goat?
  14. #149
    Mexico
    9,014
    We actually have them down here. What we don't have is La Quinta (Spanish for "Right next to Denny's") go figure.
  15. #150
    Jan 2013
    Hartlepool UK
    150
    Well spotted, schoolboy error on my behalf.
    How are you getting an accurate measure?
    Will have a butchers at it later.
