Page 20 of 21 FirstFirst ... 10 18 19 20 21 LastLast
Results 286 to 300 of 312
Thread: Tri Z Engine Build
  1. #286
    Surprise, AZ
    2,428
    LOL! Carbs are a PITA, Demel's and Q-Tips. Some won't polish at all. Low quality aluminum doesn't polish well. I was diagnosed with carpal tunnel about 25 years ago when I was plumbing compressor units. Sucks, but I've got enough pain going on in other spots that I don't notice it much now.
    Today is the first time I used white compound on aluminum instead of green, amazing! Show quality stuff. Shiny is an addiction!
    Why do I think watching you polish a carb. with a Q-tip while I am drinking a Pacifico & eating Cocktail would be funny?
  2. #287
    Mexico
    9,019
    Quote Originally Posted by onformula1 View Post
    You sound like most of my buddies down here when I work on their bikes.
    It sucks to get old
  3. #288
    Nov 2006
    southern oregon
    2,338
    So how does it run?
    2-stroke lover
  4. #289
    Mexico
    9,019
    Quote Originally Posted by cr480r View Post
    So how does it run?
    Better than I expected, but not as well as I'd like.
    It sucks to get old
  5. #290
    Mexico
    9,019
    The trike I bought in California many years ago has now returned. What a rush!
  6. #291
    NEPA
    7,051
    Have a ball out there! Say hi to everyone for me !
  7. #292
    Mexico
    9,019
    Planning to build another engine, so I figured I may as well just extend this thread.
    Started with looking for an un-cracked clutch cover to mothball for the future. After a few eBay disappointments I lucked into a complete bottom end less kick lever. The eBay photos didn't show the cover, so I thought what the heck, lets see what I can get for $150 bucks. Ended up being a compete bottom end with an un-cracked clutch cover, but it had sat with an half inch of water in it for a good while, so all the steel parts were pretty nasty. There was one broken bolt deep in the clutch cover, but I managed to weld it to a nut and then a screw driver and spun it out.
    The cases were pretty rough, but the only damage was a tab that holds a retention spring on the kicker. Was thinking of getting it welded, or just replacing the case half, but I don't think the tab is really stressed (so why did it break ) Decided to try some JB Weld. Pretty pleased with the results.
    This is what it should look like (Thanks Oldskool)
Name:	Tri Z 041.JPG
    I don't have a photo of the missing tab, but it cracked off pretty deep. I blocked and taped off the surrounding areas with cardboard and masking tape and filled up the void with JB Weld
Name:	Tri Z 037.JPG
    Let it sit for a couple days and then ground out the cardboard and tape with a die grinder and finished up with a Dremel.
Name:	Tri Z 039.JPG
Name:	Tri Z 042.JPG
    I think it came out pretty good. I'll have to mock it up with the hardware and see if it holds before I commit to getting it bored. If I have any doubts maybe it will be replaced with a different case half.
Name:	Tri Z 045.JPG
Name:	Tri Z 047.JPG
Name:	USA CELL 026.JPG
Name:	USA CELL 027.JPG
  8. #293
    Arizona
    843
    What pipe is on there--looks sweet. Maybe big enough for a big bore?
  9. #294
    Mexico
    9,019
    Quote Originally Posted by christph View Post
    Jemco out of Houston. Go back into this thread and you'll find a page on it. Not sure how it compares to a DG as I made a lot of engine mods before putting it on, but I still have a couple DG's on the wall. It's the pipe I'll be trying first when (if) I get a 350 put together. I make it look like that by sanding it silver with fine grit paper and then using a propane torch to blue the welds.
  10. #295
    Arizona
    843
    Unfortunately I heard some bad things about Jemco's quality recently. A guy on Tecate FB bought a pipe and the welds looked like tooth paste and some weren't even finished. It took forever to get the pipe, too. I'm pretty committed to getting a 350 kit for my Z. I might even take the engine out this weekend. If I need a bigger pipe I'd like the Jemco as an option, but I have some reservations after seeing that.
  11. #296
    Mexico
    9,019
    I can't say I'd buy another from them if there were other options.
  12. #297
    Mexico
    9,019
    Who do you "like" better ......onformula1 or Aramid ???
    Damn, that's a tough one! Both seem to suffer from mental issues, but only one has stolen from me, so I guess Aramid gets the nod.
  13. #298
    Dec 2013
    Coachella Valley, Calif
    124
    Quote Originally Posted by 3 Wheel Drive View Post
    Ive got an extra HD Sprock Racing base gasket if want one pm me. All the info for the Vforce3 reeds is good on the Z they will come with 4 holes no worries. Here's a pic of the reeds & HD Z gaskets:
    Attachment 209043
    Its hard to believe after all the bling on your Z and time building that trailer, you don't have those fancy reeds yet?!
    Regarding that base gasket, is it thicker? or just better sealing?
    The reason I ask is that there was a new gasket on the bike I bought..but it leaks at the base gasket, no matter if it was tourqed down to spec. Someone somewhere here mentioned the Tri Z cylinders are often warped and will not seal, is there any truth to that?
    I need all the help I can get!
  14. #299
    Mexico
    9,019
    Quote Originally Posted by this old rz View Post
    It does seem to be high quality, but the thickness is the same as what I got in a kit. Regardless, If yours won't seal, a better quality base gasket won't help.
    I'm working on some cases right now. I've removed the studs and plan to lap my cylinder to the case with valve gringing compound. I try to lap in all cases and covers if possible. Unless yours is really our of whack you can try that, but removing the studs isn't easy and the two on the left side are discontinued, so don't ruin them.
    Where is your leak? If it's where the case halves meet a dab of Yamabond on the case and gaskets might do the trick. You could also seal the entire thing with Yamabond, but I'd want to know where the problem was before deciding that was the way to correct it.
  15. #300
    Mexico
    9,019
    My bargain clutch cover being made pretty. I like to get rid of all the casting ridges in the cooling system. I don't know the exact math, but if there's a 1mm ridge all around a 17mm opening that has to represent a fairly large impedance.
    Same treatment for the inlet.
    All casting lines and ridges were removed and it was sanded smooth with 320 grit inside and out.
    Semigloss Ford Black
