Results 1 to 15 of 26
Thread: 1983 200 Headlight
    Mar 2014
    Iowa
    78
    1983 200 Headlight
    My 1983 Honda 200 headlight is not to bright. Its dim and yellowish looking...even at high rpms
    Is the bulb or a wiring or ground issue ? What should I check ?
    Thanks
    Apr 2014
    Greenville, TX
    137
    Yes all of the above. Personally I would get a good led light and mount it in your old ones place. Brighter and better unless you want to keep the original look. Rebuilding a 185s right now and I am going to update all lighting to led.
    Currently Own
    '85 Honda Big Red 250es
    '84 Honda Big Red 200es
    '81 Honda ATC 185s
    Unk yr Adventure Vehicles 3 wheeler
    Mar 2014
    Iowa
    78
    Is there a coil for the head and tail lights ?
    What runs the juice for them ?
    I have unpluged and cleaned all the connections I could find...its a little better but not much.
    Could you share what kind of LED lights your going to use for the updated lights ?
    6,798
    Lighting coil is located behind the flywheel . its the larger of the two .
    Mar 2014
    Iowa
    78
    Thanks
    Could the lighting coil be weak or going bad and that is causing the dim lights ?
    6,798
    Yes .......
    Quote Originally Posted by Mike Burke View Post
    Thanks
    Mar 2014
    Iowa
    78
    would you have a part # for the lighting coil ? I cant seem to locate it in the manual
    6,798
    Just go on eBay and purchase a aftermarket one .
    Mar 2014
    Iowa
    78
    I haven't taken it apart yet so I haven't seen It. I have a idea what it looks like but not positive. I see some Ignition coils but not Lighting coils...... Could you post a photo of one so I know what I'm looking for ?
    I'd like to have one in hand before I take things apart .
    Thanks
    6,798
    http://www.ebay.com/itm/Honda-ATC185...dc41f9&vxp=mtr
    http://www.ebay.com/itm/FL350-ODYSSE...e13119&vxp=mtr
    You will need a flywheel puller and the new coil gets soldered in .
    Mar 2014
    Iowa
    78
    Thanks
    Is it very commen that the lighting coil would go bad ?
    Nov 2014
    California USA
    77
    What model is it?
    Mar 2014
    Iowa
    78
    1983 Honda 200
    I see sometimes its listed as a 200a
    Its a pull start...just a regular 200
    Nov 2014
    California USA
    77
    1983 Honda 200
    does it still have a high low switch?
    what happens on high or low?
    is the tail lite bulb working?
    if the tail lite bulb is working you can remove it and see if your lites get brighter
    if you have at least 12 volts you could try a halogen lite around 30w . . they might be around 7.00 . . the led ones might be around 20.00.
    i think the head lite bulb is 25/25w and the tail lite bulb is 5w . . i would check and post what they are.
    you may have a yellow wire coming off the stator . . if so you can unplug it while it is running and check the voltage at idle and around 2000 rpm.
    Mar 2014
    Iowa
    78
    [QUOTEdoes it still have a high low switch?][/QUOTE]
    Yes
    It switches the beam of the light angle...but the light is still dim and yellowish looking. The brightness doesn't change.
    Yes...it works
    I will check those other things....
    Thanks
