So I have a 1986 ATC 250R that will startup (sometime), run fine for about 30 seconds then die. Once it dies it is a pain in the ass to get going again, and once it does the same symptoms occur. I put fresh fuel in it 32:1, completely gone through the carb but the same symptoms occur of it running for about 30 seconds then dying. I have owned the bike for several years know and it has always run fine before. Also, I have always run a NGK B9EGV spark plug in it because the bike would not have a crisp power band with the BR9ES the Manuel calls for. I am beginning to think I have an ignition problem because I cannot really see (confirm) spark when I put the plug against the head. Any advice/experience would be great thanks ???????? Also the bike is completely stock, as far as I know except a full fmf exhaust, K&N air cleaner and some drilled holes in the airbox.
