Results 1 to 3 of 3
Thread: What size jet
    crev is offline New to the board Arm chair racerNew to the board
    Apr 2006
    kalamazoo mi
    28
    What size jet
    I have an 85 Honda 250R. with 40 over piston fmf pipe. race ported cylinder ( top end ). stock reed cage. no air box, k&n 6inch air filter. want to put 39mm carb on. what size jets should I start with.
    NO ATV'S WE RIDE ATC's
    Jul 2014
    Lloydminster, Alberta
    503
    IMO id upgrade your reed cage as well, I've got basically the same mods as you and have a 39mm PWK on there right now I've got a 42 pilot jet and a 175 main. With the cold weather and fresh top end its still a little too lean for my liking. Elevation here is around 500m, don't know what it is there and weather wise I don't know either bud id say start with the 42 pilot and like a 165 main. I also have my needle clip on the last notch
    Mixing gas and haulin' ass
    1984 ATC 70 x2
    1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
    1985 ATC 250R-stock
    Apr 2006
    kalamazoo mi
    28
    Thanks that's a place to start
