Results 16 to 30 of 49
Thread: 200x 83'-85' head flow numbers.
    Mar 2007
    Texas
    5,045
    stock HP on these were not as much as you guys think. most were around 9-11HP. today's chinese 200CC motors that are remakes fo the old honda stuff but have higher compression are barley touching the 12-13h mark. so I would get 11 hp would probebly be about right for the 200x in stock form.
    getting 18hp out of a 200x is a big deal (we are talking wheel power not flywheel). getting 22hp range means a ton of work and stroking was done usually when proeprly dynoed by a dyno that is set "correctly" not to fudge numbers. Mustang and dyno-dynamic dynos are load bearing and thus provide a much more accurate results. Others are not load bearing and are ususally reading about 12015% higher due to inaccuracy of the dyno by not having a load.
    ________________
    https://www.mikesatvfix.com
    Hyndman PA
    1,905
    Yes every head is different. I get a lot of Yamaha Warrior customers that want big valves. A long time ago I tried a 900 Kawasaki street bike valve in them because it fit right in. I told this to Kibble White so now they sell them. What I didn't tell them is they killed the flow. When I tell customers this they don't understand that the stock valve flows more because of the back side shape. They want it anyway, so I have to tell them I don't want the job then.
    Dave8338's Avatar
    Dave8338 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2013
    Central MN
    378
    I see these numbers and have always wondered why, so few details about the specific hp and torque numbers, are available.
    Take a look at the spec sheet for a 1983 XL200R Enduro bike. Same basic design principle, engine parts, etc.
    Max Power
    18 hp @ 8000 rpm
    Max Torque
    1.7 kgf-m @ 6500 rpm
    http://www.motorcyclespecs.co.za/mod...l200r%2083.htm
    Which set of numbers are wrong. Where the above stats using HP at the crank?
    The Goal... All I Need Is The Time...
    Oct 2006
    Wapakoneta
    815
    The last time I had my 200x on the dyno it put down 27 hp at the wheels. Thats with extensive head work, a +6mm long rod stroker and 12:1 compression.
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    Quote Originally Posted by xrider View Post
    I would believe that. I am MUCH more familiar with motorcycles and how to get power out of them. A 200cc engine only making 11-12HP and extrapolate that out to a four cylinder 800cc bike and you would have a 48HP inline four ? ? ? Yes... I know the math doesn't work that linear, just making an example.
    Hyndman PA
    1,905
    Quote Originally Posted by Dave8338 View Post
    Max Power
    18 hp @ 8000 rpm
    Max Torque
    I would say those are crank numbers.
    Hyndman PA
    1,905
    Those are very high numbers, that's why I wanted to take yours and mine to the dyno I use. Now I'm just going to take mine with a good head on it because I know where it was and that will give me a idea how these Dyna Jets work compared to the Powroll dyno.
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    I think you're correct, Mickey. Be interesting to have a cam out of one of those, to run numbers on. Same as the ATC ?
    If it is at the crank, and others have stated that 11 RWHP is what is to be expected, that means that there is a ~ 40% loss in the drive train. This I do not believe.
    Any average that I've calculated and observed on several projects from 2 to 4 wheels, puts the RWHP losses in the 15% range.
    The bore and stroke numbers, match what I have going, the XL compression is lower at 9.2 :1 and the XL carb is a 24mm Keihin.
    Oct 2006
    Wapakoneta
    815
    Quote Originally Posted by Mickey Dunlap View Post
    That should make for a good comparison to the powroll numbers. Mine was on a Dyno jet as well. Curious to see what kind of numbers you pull if you put together a big bore / stroker combo. I am still bound determined to break the 30 HP mark.
    Oct 2006
    Wapakoneta
    815
    Mickey, How much of the 253cc will be stroke and how much will be bore? I'm assuming 6mm on the crank?
    The Open Road
    4,736
    while I was already aware of the fact I had very little understanding of flow when I began cleaning up some casting flaws in my intake track and incorrectly referring to it as "mild porting", I must now humbly admit that I didn`t know just how friggin ignorant I was to what is involved after reading this thread. I did study camshaft theory (a little) and had several calls in to the Megacycle rep before I bought that cam but I think it`s time I STFU and learn more before I attempt this again.
    I deserve to feel stupid for not asking more questions of more experts and now all I want to do is tear down my X motor with four hours on it and just send it off and quit pretending I`m doing any good at home on a workbench with my grade-school understanding of flow.
    Thanks for sharing the info, Mr. Dunlap
    Hyndman PA
    1,905
    I'm going to go a 8mm stroke with a safe 70mm bore, I could go 7mm but it makes everything right on the edge then. I'm keeping the stock rod with a super lite piston two ring style because we will be 4mm's shorter decks.
    Hyndman PA
    1,905
    It's not about being stupid, I just happen to work at Powroll and was told what to do and where to grind and where not to, but you still have to do a lot of R&D on each head. I'm just now after working on my v-twin Kawasaki's for 17 years to the point where my heads make a lot of power, more then I thought I would ever see. So it just takes time, and it's not all just about flow numbers. The 2 valve motors need all the help they can get and I still have more work to do. The only way I'm going to get any high HP numbers out of the 253 is a very big cam.
    The Open Road
    4,736
    two questions
    I`ve had some conflicting answers from local builders about "polishing"
    some builders told me NOT to make the intake runner glass smooth but maybe a tiny bit rough because of something called "fuel shear?" but that I should polish the exhaust runner as smooth as I can get it. Now I don`t know enough to say wether this applied to a two-valve motor motor or not as he builds and races newer machines with more valves. What are your experiences and did I misunderstand what they were telling me?
    We used to back-cut the radius between the valve and stem on our bracket drag cars for more flow but it wasn`t a lathe cut on the valve on backside of the seat area but rather I grinded them in a spin fixture on a precision grinder making the radius between the stem and the big part (name escapes me) smaller. This is NOT what you meant by a 30 degree back-cut, right?
    I like your website, BTW.
  15. #30
    Oct 2006
    Wapakoneta
    815
    Very nice. If you get it done and get rwhp numbers over 30. I'll get a motor headed your way.
