So I just picked up a 1983 (I think) YTM 200k. It didn't want to stay running so I pulled off the carb and cleaned it. Slapped it back on and I can get it to start up but still wants to shut off. Only way to keep it running is to keep feathering the throttle. It is also idling high like its running rich. Backfires a little when feathering the throttle so I think the valves need to be adjusted, something I don't know how to do. Still doesn't like to stay running.
Heres what Ive done so far: Cleaned the carb, replaced the spring on the choke because it was sticking open, replaced the hose for the carb joint because the old one rotted in half. It is getting good spark.
So I'm not very experienced with small engines or carbs. If I know what to do I can do it, but that's about it.
There is a clear/brown hose (vent hose I believe) coming from the top (not the bowl drain port on the bottom). It seems to be sucking air? if I pinch it off the engine shuts off immediately. I have tried adjusting the air screw and just cant keep it going. Any ideas? I think I need to swap the bowl gasket because it is leaking a bit but that shouldn't affect the motor running or not right?
Thanks Guys for your time. Any and all ideas are appreciated!
