Results 1 to 2 of 2
Thread: sorry posted question in wrong area
    Oct 2013
    halifax pa,
    129
    will 200x aluminum wheels bolt on to a 85 250sx if not what aluminum wheels will thanks
    Miami,Fla.(305)
    808
    Not positive- but I believe they will IF you use wheel spacers-The spacers need to be minimum 1 1/2'' thickness to be able to clear the large brake drum on the 85 model. This of course for the rears. -For the front tire IDK........?
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
