Results 1 to 3 of 3
Thread: Carb suggestions for 1984 YTM200el?
    Jul 2013
    michigan
    88
    So, I have rebuilt the carb on my Yamaha and I believe the float is sticking. After running rich for a while, the machine will begin to spit and sputter, then dump about 1/8 cup of gas back out the breather. I thought my issue was my choke, because when I went to tear into the issue, the choke plunger was corroded (probably because I didn't blow out the carb cleaner like I should have).
    I am pretty new to this stuff, quite limited on the technical tools.
    I am considering looking for a replacement carb. One that the parts are more readily available, but not sure what to look for.
    Suggestions please?
    Six Stroke's Avatar
    Six Stroke is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central Minnesota
    315
    Have you replaced the needle and seat? Often a decent-looking needle can still be bad. The wee little spring inside for the plunger sags, which can alter the level at which the floats close the needle.
    1985 Yamaha YTM225DX
    2014 Yamaha WR450F
    2008 Yamaha TW200
    1975 Honda CB400F
    Jul 2013
    michigan
    88
    Need and seat were replaced when I rebuilt the carb.
