Results 1 to 8 of 8
Thread: 200x gasket full kit
    florida
    186
    found a new old stock kit. says for 83-84 I have an 85. whats the difference if any? thanks John
    Jan 2014
    Massachusetts USA
    782
    I just built 2 of those engines last summer, and the Vesrah gasket kit I used listed all three years as being the same. No difference between those years as far as bolt patterns and flanges go.
    1985 Tri-Z 250
    1985 ATC250R
    Scootertrash's Avatar
    In the sticks
    4,638
    All the same. Throw it in.
    florida
    186
    thanks Guys. I appreciate the help
    Make sure the rubber plug is in the head oil gallery or that cam will get cooked; If ya didn't know I'm just sharing because allot of guys do that.
    florida
    186
    thanks wasn't aware of that. but I was going to use the manual have to split the cases for the ratchet gears. and have never done it before.
    In the sticks
    4,638
    Part number 5 is the plug DC is talking about. It's a tiny little thing. (That's what she said )
    http://www.servicehonda.com/parts/lo...965DE14965D01B
    Mar 2007
    Texas
    5,045
    we lost the plug for "red" years ago, what I did was take a tooth pick and use black hi-temp and slowly fileld the plug port with it using a tooth pick to guide it in. then when it dried used a razorblade to trim the top. this worked perfect and what i like is no more plug to loose!!!
    anyway jsut sharing.
    the next time we actually do a complete head rebuild, we will remvoe the silicone and drill/tap the hole for an allen screw to resovle the issue perminatly.
    ________________
    https://www.mikesatvfix.com
