Results 1 to 2 of 2
Thread: Tri-Z throttle cable with 36mm Mikuni flat side question
    Jan 2008
    nc
    734
    After finally getting around to messing with the Z, I noticed it has an aftermarket carb. What thumb throttle cable works best with the 36mm flat side? I don't know if the current cable is OEM or another models cable. thanks
    Jan 2014
    Massachusetts USA
    782
    I would bet the stock cable will work. I know a stock thumb throttle won't open a 38mm all the way, but you could probably get it to pull that 36 to WOT.
    1985 Tri-Z 250
    1985 ATC250R
