I hesitated to post this because I`m sure it was covered some time but searching for all those postings has become a nightmare.
SO when I built my first 200X, the idea was for a flattrack/ TT setup as that is what most tracks here are setup to run.
After blindly dumping cash into this machine I figured out that I`m happy with the result but I don`t think its set up for flattrack very well. I never lowered the forks or rear end with a strut. I just threw on some Duro`s and a 38t sprocket and called myself ready.....SMH.
After reading a lot more postings and determining that I don`t want to do just one type of racing, I also discovered I know little or nothing about race setups AT ALL.
SOOOOOO........I realize just in this forum we have desert racers, ice racers, MX racers, Hare Scramblers, Flat trackers on dirt, flat trackers on syrup covered concrete, TT racers, drag racers, and armchair racers (I`m really good at this one and have my setup dialed-in)
Fast forward to TF14......no flat track... good MX track.....great drag strip....great trails. So I guess since I have the time to race maybe once a year and since once a year I`ll be at TF, I decided to setup for racing MX at TF once a year and if I can find the time maybe do the one indoor MX race in KY that Ray and those OTC fellars like to go to.
SO here it goes and if you don`t want to reveal your winning setups, I get it. It won`t hurt me asking questions, though. Its been thirty years since I read a howto in 3&4 Wheel Action magazine and I don't remember a thing.
1)Engines.......got it covered....moving on
2)Swingarms.....longer, shorter, stock?....and why would you want a shorter lenght than stock swinger?
3)Nerfs....I realize what they do but do they have any drawbacks or is it a no-brainer?
4)Suspension.....is longer travel better for MX or is it all about rebound and compression and dampening mostly?
5) Sag front and rear.....any explanation of why this needs to be addressed would be a tremendous help to me. Thanks ahead of time.
6) Tires.....I know lateral sliding ability would be important and I know that taller and farther apart lugs are for soft and loamy and tight short lugs are for hard pack. Is there anything else to consider?
7) Clutch use.....I ride a four stroke 200X so mine is either engaged or not. I don`t feather it ever because I`m not sure why I should. With my CRs and more powerful bikes, I feathered it because I hated trying to keep the front wheel down but again, I`m not an experienced racer so I don`t know crap. My armchair has a clutch handle for raising and lowering the footrest.
8) Rear Axle width....I have a Durablue 3+3 I think it was and I know wider= more stable but why would they make it adjustable? is there a reason you would want to make it narrower than 6 over?
9) adjustable shock mounts on swingarm.....like a westcoast has a whole array of mounting holes on the 250R model so what situations would you need to raise/lower it?
I apologize if these have been covered before and aggravate the more seasoned veterans but I`m just trying to learn and I can think of no other way than the proverbial Dumb Question. Thanks in advance and I will warn you that at some point I will ask all the same questions about setups for all the other types of trike racing but for now, just MX answers are good for me. Too Much Too Fast and my head will explode.
