Thread: Drilled Keihin jet is a number????
    Smile Drilled Keihin jet is a number????
    Okay, when I jet I use a nice set of drills and step it up to a good color. Local shop won't let me place my drill in the jet to obtain a size.
    I am at .063 on a Keihin FCR long hex.
    Anyone know if that's a 160 170 180 etc.?? Thank you.....
    Surprise, AZ
    2,428
    A 1/16" bit = .0625
    A wire size #52 = .0635
    I don't show a .063 = 1.6mm Where did you get that? I thought I had every drill bit!...LOL
    A 1/16" bit fit perfectly in a #160
    Let me know if I can help out, I have every jet size from #110-#192
    May 2011
    eden,ny
    3,481
    I believe it was sudco that had the jet numbers and actual size.
    Thanks so much guys!! I can tell I'm very lean but thats probably because the last thing I did was pop on a ported head and an FCR carburetor. And 13 discs on a Supertrapp.
    Thanks again and see you soon Ben!!
    Dave8338's Avatar
    Dave8338 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2013
    Central MN
    378
    Good info in this thread. Pull a few disks out of the ST and set out for some plug chops.
    The Goal... All I Need Is The Time...
    Nov 2014
    California USA
    77
    As onformula 1 says . . .063 = 160 keihin
    Fuel flow thru a jet is affected by a few different factors these are length of jet, size and shape of taper entering and exiting the hole, rifling and hole size . . rifled jets should neve5r be drilled . . because the taper affects the jet a non rifled jet should not be drilled more than 2 sizes larger and really just 1 size would be preferable, otherwise it gets difficult to know what that jet really equates to in a non drilled jet.
    Keihin jets are easy, the following is an example.
    100 = 1.00 mm
    155 = 1.55 mm
    170 = 1.70 mm
    Jet brand conversion chart
    http://www.jetsrus.com/FAQs/FAQ_miku...ihin_sizes.htm
    Some number drill sizes fall between mm drill sizes and vise versa so you need a drill size chart . . mm drills might be a bit hard to find . . try an industrial hardware store, tool supply or graingers if you need them and can’t find them.
    This chart has number and metric drill sizes.
    http://tigercaminc.com/?page_id=45
    heres a mm to inches and inches to mm calculator
    http://www.electricscooterparts.com/...lculator2.html
