Thread: new ytm 200 won't start
    Feb 2015
    appleton wi
    5
    Hello I just picked up what I believe is a 83 ytm 200.
    Fixed the recoil, cleaned tank and carb. Checked timing valve clearance, good spark. I can not get this thing to fire.
    i push started once and got one lap around the yard. Now my driveway is to slippery I cant push start. Plug is wet, good suction with hand over carb. When I hold the throttle open it doesn't want to pull over very easy. Also the cable for the starter plunger is a little sticky but seems to work.
    I've never seen a starter plunger set up, I use to chokes, am I missing something? I do not have the right adapter for my compression tester. But I had it running and did a lap so I'm am lost on what to try next. I am going to get a longer pull rope as well had to cut it a little when i rebuild it, maybe I'm not getting enough revolutions.
    Thanks for any help. I also could use a new drum sheave for the pull start has anyone tried installing a bushing into one of these?
    Feb 2015
    Mattawa,Wa
    35
    Put it in high gear when you pull start it or push less torque on the wheels. But sounds like a carb issue. Make sure your on switch is on, and your plug hooked up. I'd get mad when I forget.
    Feb 2015
    appleton wi
    5
    Well I'm kinda passed and very happy. The choke cable it a little worst for wear or needs adjustment. I thought I had it all the way but after much frustration I pulled it and in move about an additional 3/4". Then it started right up.
    Anyone know if there is an adjustment on the cable
    YamaBoss's Avatar
    YamaBoss is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2014
    Minnesota
    251
    There should be an adjustment on the cable
    http://www.oscarmayer.net/atc/manual/
    Download a manual. They can help explain it. I would download the factory 200 manual or the clymer manual.
