Results 1 to 12 of 12
Thread: 85R Pipe and Muffler Cleanout?
    Onetrackmind's Avatar
    Onetrackmind is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2015
    Allen Texas
    399
    First off... my apologies if this has already been covered to death. I did a forum search and didn't find much on the subject.
    I am about to rebuild the carb and rear caliper/master cylinder on my 85R (that I have only owned for about a month) and while I am at it, I would like to go ahead and clean out the exhaust. It has metric S__T TON of carbon build up in it which I'm positive is robbing power from this beast.
    I don't own or have access to an acetylene torch to burn it out. Is there another way to clean these two parts out on my own?
    Thanks in advance!
    Jul 2014
    Lloydminster, Alberta
    503
    Go to a wash bay or if you have access to a pressure washer, spray some degreaser or something like that in there, then go to town inside there, thats about all i can think of
    Mixing gas and haulin' ass
    1984 ATC 70 x2
    1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
    1985 ATC 250R-stock
    82 250r's Avatar
    82 250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    Utah
    278
    Go to walmart and buy a propane torch. slower than acetylene but works.
    Jan 2015
    Allen Texas
    399
    Ok, now a propane torch I DO have. I'm sure it will take some time, but at least I have the tool. Just heat up the exterior, start at one end and work my way down? I guess I could then take it to the car wash to clean out what is left...
    Thanks guys.
    Dec 2011
    Grand Rapids, MI.
    679
    Just throw it in the fire, if there is a finish you want to protect just hang it over top. But then follow it up with a pressure washer like already said.
    1986 KLT 185
    1984 200S
    Jan 2015
    Allen Texas
    399
    Thanks for the replies. Does the same technique go for the muffler as well?
    Dec 2010
    Back in VA baby!!
    711
    no need for the muffler...just get new packing
    S3 repros
    Trikefest '12 '13
    86 350x
    87 250sx
    84 70
    78 90
    Reproducing hard to find parts...check out the store
    Mexico
    9,014
    Saw a video the other day of a guy who frays the end of a 2' long wire cable (1/4"OD?) and sticks it in a hand drill chuck and puts it inside the pipe and lets er rip. Gets a bunch of crud out. Wear your helmet and goggles at the very least!
    It sucks to get old
    Surprise, AZ
    2,428
    Wow, that is sooo old school I forgot about it! Thank You.
    BTW- it works great...Link?
    Jun 2003
    englishtown NJ
    2,676
    a friend of mine poured in diesel fuel(half gallon, maybe) and a bunch of sheet metal screws. Plugged up the ends and shook it around for several minutes and poured out was was inside(most of the screws came out with it), put in super clean de-greaser, plugged up end, shook around and drained. All the screws came out and it was very clean inside. If its not a chrome plated pipe, you can heat it up with MAPP gas torch to get it 100% cleaned out. On my dirtbike, I poured in super clean, shook around and poured it out......wow........talk about black nastly stuff that came out of that pipe.
    Jan 2015
    Allen Texas
    399
    Great ideas guys, thanks. I just read on a Honda forum about plugging up one end and spraying several cans of Easy-Off oven cleaner in there then dumping some rocks or nuts (not from a tree) in and shaking it around. Might be worth a try...
    Surprise, AZ
    2,428
    Quote Originally Posted by Onetrackmind View Post
    If your silencer is aluminium don't use oven cleaner on it, use carb cleaner & wire wheel the perforated core.
    If you have a thin aftermarket pipe watch putting anything in it a shaking hard or you will have dings from the inside out.
