Do you need the correct tubular rad brackets to bolt them on or just make little 1 inch tabs for spacing back?
Thanks
Thanks
IDK if you can mod it but the kit came with relocation mounts. SOMEONE has reproduced those....
a guy on trx250r.net reproduced the same radiator brackets. Its not hard to move it back with the use of the torch and metal. Basically the top of the radiators are moved back about 1". If you have any kind of skills, this isnt hard to do w/o factory(reproduced) brackets.
I made small tabs and moved the top mount back about 1 inch and left everything else alone pretty much.
who makes a small fuel tank? i am asking because my son's racing quad really needs a smaller fuel tank. the stocker is WAY to big for the amount of fuel we use.
________________
https://www.mikesatvfix.com
