Neutral switch
I have just purchased a 1985 125m which runs ok as long as the neatral wire is put to ground. This means the neatral light is on perminantly but if I unground the wire the trike will not start.
Can anybody tell me how to remove and repair the neutral switch or are there any videos on this topic.
Thanks for any help
Here are some pages referring to those neutral + reverse safety switch's > http://www.3wheelerworld.com/search....archid=9326622
Those switch's are rare to go bad,,, normally a simple connection issue.
john
Thanks for the reply John but I think the link is bad. Says nothing found when I click on it
Hmmm, did not work for me either. I will try it again,,, http://www.3wheelerworld.com/search....archid=9326800
Okay, I double checked this time and works for me now,,,, hopefully for you to Pugs
P.S. I believe the 250es bigred and 250sx both use the same switch set up that on your trike so you might want to scan those links over as well.
Sorry John but still no luck. I will try different searches.
Can you or anybody on hear tell me if I pull the green wire out of the loom connector that goes to the neutral switch and connect the ohms meter to the end of the neatral wire and then to earth should I have continuity in neatral and none in gear. Mine is no continuity all the time.
//ArrowChat Integreation Code
