Results 1 to 2 of 2
Thread: 110 dead spot
    hdd is offline New to the board Arm chair racerNew to the board
    Dec 2014
    Alabama
    35
    110 dead spot
    Atc 110 when I crank up idles fine but when I push throttle it dies if I let it warm up good runs pretty good but still has a dead spot in throttle changed carbs and still does it thanks for the help
    Cold Lake, Alberta, Canada
    3,019
    You'll need to give a little more info. What year? If it has points your timing may be off. Make sure your carb is perfectly clean and is set to factory specs.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
