Results 1 to 10 of 10
Thread: 85 200s tranny help
    Jul 2013
    mo
    327
    85 200s tranny help
    http://youtu.be/X_FuT4aeYaw
    So ya scored this girl for 100. Really would appreciate some help to figure out tranny. Really dont wana crack case hoping i can get away with just removing clutches and fix from there. Thanks guys.
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Scootertrash's Avatar
    In the sticks
    4,638
    So are you saying that it doesn't go into gear?
    Go easy on that rear fender. You can't get them any more and when you do find them they cost an arm and a leg. There aren't aftermarket ones with the storage compartment in the rear of the fender like that.
    Jul 2013
    mo
    327
    she wont go into gear the shifter detent piece im pointing at in the vid was in the wrong place . the 10mm bolt was way loose. so we will see if it was loose cause someone took it apart to look or it was the problem they didnt see so ill throw some loctite on it and see if it works. and she wasnt laying on the fender just the tire and handlebar. i wouldnt let that happen to her. i just still am shocked to find any 3 wheeler in this shape that hasnt been rebuilt.
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Jan 2014
    Massachusetts USA
    782
    Yup, I've seen those loosen up. Make sure the spring isn't pinched under the detent arm when you tighten it up, and that the shoulder bolt locates properly in the arm. If the bolt is tight and you can pry the arm back with a small screwdriver, and have it snap back with spring action, you're good. Also, try pushing in on the shifter shaft (towards the shift star) when shifting it with the case cover off- the case cover is what holds the shaft tight against the star.
    1985 Tri-Z 250
    1985 ATC250R
    Jul 2013
    mo
    327
    ONE LOOSE 10MM BOLT! the bolt for the shifter detent. thanks for the help guys.
    http://youtu.be/hG4Q_BS9VQU
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Jun 2009
    Leander TX
    2,217
    I love the vinegar tank cleaning. I used to use pool acid. Vinegar is easier to use.
    Nicely done for $100
    In the sticks
    4,638
    Congrats!! Another 200S back on the trail!
    Jul 2013
    mo
    327
    thanks man . ya i cant stand hearing things like "hey man what happened to those wheelers behind your shed" "oohhhh i was low on cash so i took em in for scrap"
    so glad the tranny was an easy fix and shes already turning heads and people wallets start coming out and i tell em just put it away cause this stray found its home!
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Jul 2013
    mo
    327
    Quote Originally Posted by jb2wheels View Post
    ya i feel bad it was so easy to fix that i havent told the guy i got it from that the problem was one 10mm bolt. but he shot me the 100 dollar price tag and i didnt dare hagle him on it soooo.im gonna go see about getting that horrible trail pro tire off the front as its to wide for the forks and hard as a rock. and that apple cider vinager trick is the best ! always amazes.
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    In the sticks
    4,638
    I'm going to be trying the vinegar trick this weekend on an 83 200 I'm saving for a buddy.
    Swap out that front tire for a Kenda Front Max.
Name:	Fri 12 28 12.4.jpg
