Results 1 to 15 of 19
Thread: 200x 1mm oversize valves, worth the money?
    Oct 2008
    Reedsport Oregon
    856
    hi i have a modded x (cam. hi comp, 28mm carb, exhaust) i was considering the 1mm oversize valve (intake) but my valves are fairly new and i dont know how much performance or where in the range the power will be affected by this was hoping for some opinions.
    thank you
    Suzuki ALT 50: Skeeter
    Suzuki ALT 50: full suspension kit: the grasshopper
    Suzuki ALT 125: The Toad
    Suzuki ALT 160: Was a Quad runner 160: The Tri-Runner
    Suzuki ALT 185: The Warthog
    1979 Subaru brat: daily driver almost 400k runs strong
    NEED ALT 50 SEAT PAN
    Dave8338's Avatar
    Dave8338 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2013
    Central MN
    378
    Hard to say...
    The stock head will need to be ported for the new seats. Pockets smoothed out, etc.
    It is without doubt, that the stock valves/heads are the bottleneck in the equation. I think it all boils down to how much does one want to spend, chasing a few extra ponies.
    The Goal... All I Need Is The Time...
    Oct 2008
    Reedsport Oregon
    856
    its been flowported already, a few ponies is ALOT on a motor that only puts out mid teens on the dyno!
    Mexico
    9,018
    If you don't open the seat to match the larger valve it's not worth it, but you need to be sure the seat has enough material to allow it. In saying that 1mm mm isn't much, shouldn't be a concern for you. If you have the larger cam and carb already it would pick you up a bit, but a larger exhaust valve to make a matching set is what would really make a difference.
    It sucks to get old
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    Yeppers ! ! Too bad that without a complete weld shut, milling, and new valve angle, it is all but impossible on these little monsters.
    Someday, in all my boredom, I would like to attempt a 4-valve head setup. It is possible but the machining and cam production would cost a fortune.
    NEPA
    7,051
    Unless you are running this thing a couple hours a year,or less. Save the aggravation. Be happy with what you have lol.. You will get into reliability problems stretching that little girl much further...Top or bottom. Seen it a lot of times.
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    Quote Originally Posted by hawaiirider View Post
    I agree ! ! !
    Quote Originally Posted by atc007 View Post
    Very true. Somewhere in the middle headed for the top, is always comfy...
    Now that I saw thew 30 degree cut 200X valves Mickey Dunlap showed us, I think that might be a good option......
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    Certainly has to be cheaper. Have a link? I must have missed that.
    Mar 2013
    Baldwin, Wi
    603
    Post #33 has the picture of the valves he's talking about.
    http://www.3wheelerworld.com/showthr...d-flow-numbers
    85 Tri-z Basket Case
    Jan 2014
    Massachusetts USA
    782
    Quote Originally Posted by Dave8338 View Post
    It has been done using a VT250 cylinder head. See the article below, lots of good info in it, so I saved it to my pc.
    http://www.google.com/url?sa=t&rct=j...,d.aWw&cad=rja
    1985 Tri-Z 250
    1985 ATC250R
    Oct 2008
    Reedsport Oregon
    856
    Hyndman PA
    1,905
    The first thing you need to know, is how much does it flow now. You said it was flow ported already but what are the numbers. I can tell you if you send the head in, but any other opinions other then that doesn't tell you much, you are just confusing your self.
    Oct 2008
    Reedsport Oregon
    856
    i have no idea mickey, how much do you charge to set me up with the larger valve if i send it in? i know youll have to re flow port it.
    Hyndman PA
    1,905
    I don't charge anything to check the flow, but if I install the big valve and valve you are looking at $50. First check the flow and go from there.
