Results 1 to 3 of 3
Thread: 86 T3 brake caliper
    Ragar is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2015
    Eau Claire WI
    186
    86 T3 brake caliper
    Need a Front Brake Caliper.
    Or rear I think they are the same.
    Im digging threw he parts swap do the 85 or T4 swap in with a braket change?
    Found out mine was, lets say, improperly installed.
    I dont even know, how do you miss this bad.
    He put the disc, on the outside of the pad so its been using the caliper as a brake pad. and chewed it.
    Im hoping someone has a spare they will let go.
    let me know a price.
    Sep 2005
    MICHIGAN
    2,027
    I have a front caliper in need of a rebuild but I have some one else asking for one too.
    Here are details:
    piston came out with loud pop using compressed air. Seal seems ok.
    Was some brake fluid still in there. All threads good.
    Bad- all the rubber boots. Some nicks and dents on body, master up top was broken and rusty banjo bolt. Line looks ok.
    Good candidate for rebuild. Or just some rubber boots. That's all I would do.
    The rubber boots and seals are all still available. Try www.partzilla.com
ID:	210941   Click image for larger version.
    86 T3
    84 T3
    86 KX250
    Sep 2005
    MICHIGAN
    2,027
    Here is an ok looking 1985 brake:
    http://www.ebay.com/itm/1985-kxt-250...1c91e7&vxp=mtr
    Would be cool if someone would try swapping the brackets. I think the Tecate 3 brakes are all the same as they use the same rebuild parts. They look the same and same manufacturer.
    86 T3
    84 T3
    86 KX250
