Thread: Need some 200x help please
    Jonathan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Ok, I'm tearing my 84 200x motor apart and I can't seem to get the oil rotor nut off, same goes for the clutch nut thing. I have the special wrench to do it with but the nut won't come loose. I've even banged on the wrench with a 2 pound . Thanks for any help.
    I like motorbikes!
    200xer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    edit: I read your message wrong.
    Washingtons Crossing, Pa.
    2,977
    .... Try tightening it - I don't think it is, but it might be reverse threaded.
    Jonathon;
    I just had my 200M motor apart and it definitely was a left handed thread on the oil rotor nut. The nut was also "staked" down by a center punch into a relief on the shaft. It will move easier if you lift out the staked down portion. I don't remember the clutch nut being left handed though. It spins in the opposite direction so a left handed thread would not make sense there. Put your transmission in top gear ( 5th or 6th ) and put your chain over the chain sprocket on the engine. Use a screwdriver to hold the chain from spinning and this might allow you to get enough torque on the nuts to remove them. Good luck, GlennMc.
    Guest
    nut
    NO NO NO!!! the nuts are Right Handed (tried it on mine the first time....no manual!!!) as far as gettin it off....i had no problem.....does the transmission turn when you try to loosen them??? if so it says to stick a penny (COPPER) in the gears.....the penny will give before the gears do....hope this helps...let us know
    Brad
