What are the pros & cons of putting heavy duty spring instead of oem? I plan on putting a 200sx quad motor in a 2nd gen 200x frame and I'm curious what would be the benefit of using them. The oem spring are within spec so I can still use them. Will heavy duty springs negatively effect performance? I will be going up a piston size and have a wiseco 10.25:1 if it makes a difference. I may use an aftermarket exhaust if I can find one. Thanks.
