Results 1 to 4 of 4
Thread: atc250es choke lever set
    6,811
    Are the choke lever sets the same for all years ? I need one for an 85 model and 86-87 show a different part number .
    NEPA
    7,051
    6 and 7 are different. Last I knew 85 isn't available separate?? Newer ones are? Last I bought that's the way it was 85 SX ES and TRX are all the same,,,but will be brittle if you can find a used one ...
    6,811
    85 shows separate but discontinued , 86 and up is available new and easy to find . I don't have both to see if their interchangeable , somebody must know ?
    NEPA
    7,051
    I see now what you're after ... I haven't tried putting the newer ones on a 85.. Also the TRX 300's are similar.
